Kyosho Ultima RB5 Thread
#9092
Before you do check your rear trackwidth. As I think you will find the car will be to wide with the 3 line axle with the spacer on the outside as the picture shows.
Increase by 4mm trackwidth as the pic shows.
The 3 line axles actually go right back to the first RB5 the arms were 2mm shorter than what is now kit standard. The SP/SP2 length of arm is the same as the worlds update(LA243) arms just different shock mounting configurations.
#9093
i currently have a orion 1106 servo that i am trying to use in my sp2.the problem with this servo is that when i put it in the shaft of the servo is way to long for any servo horn to fit flush on the servo! i cant put it on all the way at all! i tried re centering it and cant get it on.it hits the steering posts and the steering link as well.everything is ready to go.all i havd to do is fix this problem.why is tge shaft so ling to begin with? am i stuck here or do i need to buy another servo? ive tried everything and nothing works with this servo.
what orion/ko servos are people using? i really need help with this because i have to run it tgis weekend!
thanks
thanks
#9094
thanks
thanks
#9095
thanks
thanks
If you are using the correct horn, you may need to adjust the spacing of the servo back from the steering posts. There are spacers for this supplied in the kit as well.
#9096
Are you using the correct horn for the Orion servo? The common tooth numbers are 23, 24 and 25 for servo shafts. These 3 are supplied with the kit and should suit most servos, just need to find the right one for the number of teeth on the Orion servo.
#9097
How good are the RB5 sp2 holding up?
#9098
[IMG][/IMG]
#9099
ive tried spacing and all this is the problem as shown in pic! if the horn would go all the way on i would be fine.the shaft of the servo itself is way to long.the horn is a 25t futaba servo horn. very odd
#9101
is that the 1106?
#9103
that would explain why yours fits the shaft on yours is shorter than mine.i have the orion digital vds 1106.why would they make a servo with the shaft that sticks out that far? i used it in my fs2 and it was the same way but it worked due to the fact that there was enough room. so it didnt matter.i just thought these servos were supposed to be like that from factory
oh well either i cut the shaft or buy a new one
#9104
Honestly it just looks like you need to tighten the hell out of it to get it down
#9105
