Kyosho Ultima RB5 Thread
#8656
ok i got my sp2 almost built.question now is regaurding the rf-rf2 rear toe parts.i read that there is a matching rear arm holder for each,so which is which?one rear arm holder has screw holes that run all the way up from the bottom and the other one has the screw holes stopping in the plastic?also are you guys not using the antisquat shims?thanks
#8657
#8658
ok thanks!
#8659
im in the process of building my sp2 and have noticed that there is binding in the front arms.any suggestions on what may cause this?
#8660
R/C Tech Elite Member
I had that happen to me also, when I was building my "SP". One side would bind a little more than the other. I think it was eventually between the the pin keeper screw, and the set screw on top of the pivot block were working against each other-try backing the keeper screw out a little-should set it free..
#8661
#8662
tip on front inner hinge pins.. leave the set screws out of the pivot block.. the front bumper will hold the pins in perfectly fine and make front arm changes much easier
#8663
ok i got it built!i used a b4 gear set because the track i primarily go to is tight.its geared at 72/28 with a 17.5 motor.i thought i read somewhere that the ae spur gear would work fine but i cant get the slipper to lock down.i used the ae slipper pads as well.when i hold both rear wheels and hit the trigger all i get is a zing sound!the front wont pick up at all.any thoughts?also i have 1.5 oz in the nose.
#8664
#8665
#8666
I've found diff adjustment on the kyoshos are a little more touchy than other vehicles , like the above post said sounds like Ur diff is loose. Id also suggest ditching the stock diff balls for ae carbide or ceramics as they last better imo . Also breaking in the diff helps too, I do mine with a drill , some do it when its in the car
#8667
well the car is brand new!never been ran yet.does both the ae gear and pads work properly?
#8668
forgot to mention i did use the ae diff balls also.it looks to me like the two metal discs that sandwich the gear and pads is a shade to big to fit the recess in the gear.just guessing though.its a 72 tooth gear.
