Kyosho Ultima RB5 Thread
#8312
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
the BB tower is taller and I am currently not running it. I just dremel the standard tower. if you run the bigbore tower you will need to run a longer shock end and even then it makes the car different.
#8313
here is the shock tower for the front of the rb5, and both for the rt5. the strap is kyosho, but I can come close to duplicating it. cant make it the same or I would most likely be sued. I will have to make the shape a little different or possibly have the holes cut the entire way through... what do you guys think?
#8314
Does anyone know where you I can get the aluminum battery posts with screw on bolts like tebo runs?
#8315
#8316
#8317
has anyone tried an RB5 with an RT5 to get a slightly longer wheelbase?
#8318
yes, i understand this, look at tebo's car. he uses the alum. front axle as his batt. posts. have a look for yourself![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
http://www.xfactoryrc.com/rc/Galleri...ut-Jared05.jpg
#8320
#8321
#8324
what is an LWB RB5?
