Kyosho Ultima RB5 Thread
#7804
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
indoor clay track.. im sure the track change has some to do with it.. but it was like that all day..
i changed front tires.. and it helped some.. so the car wasnt so darty.. im gonna do some more testing this weekend.. try to lay the shocks down some.. see what happens.. the camber links.. maybe..
#7806
Hey what up thanks for the info i will try it out.
#7807
if you boost the timing or whatever.. you may could go with a smaller pinion.. but.. with no boost.. i think a 72/30 will get you in the ball park..
#7813
I am having a slight problem with the rb5 setup if anypone could help. I cannot seem to get my car to pull out of the corner as hard as the other cars. Still doing very well with the car, but i am loosing .1-.3 a lap because of this.
Running on a high bite indoor dirt track, smooth about 50x90.
I would like to get this worked out before the jconcepts winter indoor nationals but I have not found anything to work yet besides making the rear loose, but then it is hard to run consistent lap after lap
#7814
#7815
