Kyosho Ultima RB5 Thread
#2491
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Yea i replaced the front knuclkes and shims and rear hub carriers last night and also the eyelets on the bottom of the shocks. I was tempted to put all new arms on but i wanted to save them. I need some rear pivot blocks i replaced them once before. I guess I should re do them again and my front hinge pins were out of the aluminum bracket thing which is bent, I might replace that as well. i wished i would have noticed that. My car just feels like crap lately. I also have alittle play in my servo. Should i replace it or can i rebuild it ?
Boy was my car a mess !!
#2492
Most servos you can get replacement gears for, some servos lke airtronics that claim "metal gear" still have one plastic gear that can strip/wear, good part is its $5. I went through 2 of those front hinge braces when the car was new and I endo'd too much. Seems like some people I have talked too don't like the way the car feels even though times are about the same, I imagine setups need some tweaking for the "winter" track.
I have a z8800s servo what would be in there to rebuild ? anybody know ?
Yea i think its just slop in the car and the weather. I am adjusting.
#2501
![Lightbulb](https://www.rctech.net/forum/images/icons/icon3.gif)
I would like to know what the rear hub vertical positioning does for your setup. There are three positions Up, Middle, and Down. I am running in the up position, which I believe is the standard position.
Also, what is the difference between the 1 degree hub (LA244-0) and the 0.5 degree hub (LA244-05)? What does the use of the 0.5 degree hub do for your setup?
Thanks.
Thanks.
#2502
Raising and lowering the hub effects the roll center of the car. The upper holes will lower the rear roll center and the lower holes will raise the rear roll center.
Higher rear roll will increase on-power traction, decrease traction under breaking and decrease traction rolling entering corners.
Lower roll center decreases rear traction but will help reduce mid-corner and exit traction rolling.
The best advice since this is a very easy change to make is move the hinge pin and see what it does for you track conditions.
The stock hubs are zero offset. The .5 deg hubs will add .5 deg of toe in. This will lock in the rear of the car a little more and should be used in low traction conditions where you need more straight line traction. More toe in will lock in the rear end more but will scrub a little speed off the car.
#2503
I tried the 0.5 rear hubs on our loose outdoor track and thought they were pretty good. Added a bit more stability. Top end speed wasn't an issue as I was running a pretty hot motor anyways
However at a recent smaller indoor track, I found that it increased the push of the front end, so I went back to the 0 degree hubs. It's a decent tuning aid though if you race on a variety of surfaces.
#2504
Another notch on the win belt for the RB5. Duked it out at the Canadian Hobby Show Championships with some Losi and A/E sponsored drivers and other fast locals from Ontario and Western New York. TQ'd and took the A Main win. This car is so easy to drive aggressive and the Orion LiPo/Brushless combo is awesome!
Some videos of the racing action if you are bored: http://www.sidsraceway.com/results.htm
Pretty fun little layout for a temporary track.
#2505
Nice orange turnbuckles..
