Kyosho Ultima RB5 Thread
#1877
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
More caster will give you more steering in high-speed corners, where there is more chassis roll, and also while turning in. It will also make the car more stable in rough conditions, and the car's straight-line stability will also be improved. Less caster will give you more steering in low-speed corners, and less turn-in.
#1878
I've always tried to use the least amount of caster I can, and use other means (throttle) to work the fast stuff.
#1880
Guys,
I know there are lots of pages of info, but could someone give me a quick list of what I would need to get setup with this buggy? Things like common broken parts, tuning options and Losi or AE parts that are used as an improvement over stock.
I am thinking of switching over from my X-6. The buggy was great until I switched to Lipo's. Since the X-6 is designed to have lipo's lay across the chassis and all the other buggies would have the lipo brick lay along the vertical line, I think that is the better layout. I can feel how the X-6 seems to wallow through turns now. Since I have Kyosho 1/8 buggy and truggy, I wanted to stay within the family.
Thanks.
Thanks.
#1881
Regional Moderator
![](https://www.rctech.net/forum/rctechv3/special/techelite_alt1.gif)
Guys,
Thanks.
Thanks.
#1886
What does raising and lowering roll center do?
#1888
I tried it back to back with the arms all the way down and arms all the way up.
All the way down (lowest hole on carrier) make the car feel super nervous going into "on-throttle" corners and coming out of turns
All the way up (highest hole on carrier) was just the opposite...car was far more planted and felt stuck in the rear end.
Havn't messed with the middle hole yet but I can imagine it would be somewhere between both of those holes as far as rear traction and rotation went.
maybe a combo of caster and rear carrier height would work out pretty good?
#1890
Does anyone but me notice that the battery tray seems to get jammed up with dirt a lot?
I run Lipo, so I don't pull it out every run, but after 2-3 runs, the battery area has a bunch of dirt in it. I'm assuming it comes from the wire slots and around the T-plate...I was thinking of sealing it up with a little RTV, but I'd rather not...is it just me?
The car is great though.
This is what I thought 2wd buggy would be like -- light, nimble and fun to drive.
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
