Team Associated B7 and B7D
#1667
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Just a quick video of the stock transmission case I received - press fit
#1668
https://www.youtube.com/watch?v=omwWQyXxqYM
1. The diff screws are not tight enough and are rubbing the bearing holder. It is wise to use a 2.5mm hex head screw to make the threads in the gearbox case prior to using the countersunk 2mm screws and make sure that they go in square.
2. The diff screws are too tight and have deformed the teeth on the outside of the diff casing
HTH
#1670
This is what we call "total bind free" drivetrain
This B7 uses stock ball bearings
https://www.facebook.com/share/p/tcS...ibextid=oFDknk
#1671
I saw this video that shows updates to parts like
- Diff case cover
- C-block
- Front shock tower protector
Seems good updates but I cant find more info like: when released, kit and/or sparas, new/same artNo?
Anyone who knows?
Video on YT:
KSHoeKheISA?si=mpWtLBbHwAXc6ftl
- Diff case cover
- C-block
Anyone who knows?
Video on YT:
#1672
Seems to be a running change.. So safest bet would be to buy the revised kit. I think the hobby shops will sell the old parts first.
#1673
