Losi 1/6 Super Baja Rey Thread
#395
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
I imagine it will look terrible after the crash.
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
https://rover.ebay.com/rover/0/0/0?m...2F263931098479
#396
![](https://www.rctech.net/forum/rctechv3/special/techelite_alt1.gif)
they are specifically made for the sbr.
I imagine it will look terrible after the crash.![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
#398
![Thumbs up](https://www.rctech.net/forum/images/icons/icon14.gif)
Thought I would show a pic of my rig with the Badlands. It's got a ton of grip now and it's much more stable also. Very hard to roll it as it's 30mm wider all up.
I'll have to trim the front wheel arches as it's rubbing.
I also put a brace on the rear of the roll cage. It works great too, it stops the roll cage from twisting and as
much without the rear panels, which was something I noticed in videos I've seen. I can twist the back of the cage with my hands and the whole truck moves
instead of just twisting the back part
#399
Length139mm / 5.47in
Width48mm / 1.89in
Height37mm / 1.46in
Weight499gr / 17.60oz
Trying to buy 2 3s lipos for my SBR but the only thing that concerns me is the height. When I measure battery case it seems like it will be a snug fit. Have you all had any problems or believe 2 will fit? Or reccomend any batteries? These SMC lipos are 7400mah are $63
Width48mm / 1.89in
Height37mm / 1.46in
#400
Width48mm / 1.89in
Height37mm / 1.46in
Width48mm / 1.89in
Height37mm / 1.46in
My batteryDimensionsLength139mm / 5.47inWidth48mm / 1.89inHeight37mm / 1.46in408gr /14.39oz
![](https://cimg7.ibsrv.net/gimg/www.rctech.net-vbulletin/2000x1504/20181010_214717_29fdb2dcbfe6e7c0bb7f731045f1f835f919683c.jpg)
#401
#402
yes I use two, just tight fit. I also moved battery foam from the door to front of battery tray to move weight bias more towards the rear.
First picture shows comparison of battery height between smc batteries I have and the recommended dynamite reaction 3s batteries that horizon recommends.
![](https://cimg6.ibsrv.net/gimg/www.rctech.net-vbulletin/2000x1504/20181010_234032_9c815edb5a70fececdbddeb27b7db8840e7e5ff5.jpg)
![](https://cimg0.ibsrv.net/gimg/www.rctech.net-vbulletin/2000x1504/20181010_234425_951726b4a27a5a27ead84c5746b50170b4334bb3.jpg)
![](https://cimg1.ibsrv.net/gimg/www.rctech.net-vbulletin/2000x1504/20181010_234447_8a8e17874fb8646607827f5e78be712cdddf821b.jpg)
#403
4500 mAh.
#404
My smc 4s lipos don't balance very well, but it might be my balancing board. I'm not sure on the runtime, maybe 10 minutes if I'm running hard. I take breaks and stuff.
on 8s you will more than likely kill the stock foam inserts.
Shock covers are from rc-skin
#405
I will just be running 4s not on 8s that will be two much power and wont fit. On facebook I saw someone extend the battery case. Might consider it if my 3s are to snug
