Kawada M500WGT-X
![Arrow](https://www.rctech.net/forum/images/icons/icon2.gif)
Taking Pre-Order now!
Kawada M500WGT-X
![](http://banzaihobby.com/images/M500WGT-X.jpg)
Kawada M500WGT has been upgraded to X! X comes with loads of high quality option parts.
Kawada M500WGT-X comes with following NEW Products.
SDS Front Suspension End (RGT100)
SDS Supension Sus plate (KDB102)
HG Tube Damper (KD77)
FX3 Motor Mount (RSD06, RSD07)
Carbon Motor Mount Brace (KDB08C)
Large Diff Ring (RSW30)
Technical Data
1/10 Scale
MADE in JAPAN
Wheel Base: 258mm
Width: Front 192mm, Rear 195mm
Tread; Front 163mm, Rear 144mm
Driect Drive 2WD
Ball Diff
Front Independent Suspension(Friction Damper SDS)
Rear Link Suspension
Front Caster: Adjustable
Servo: Mini (not included)
Moto: 540 Size (not included)
Required Items
Radio Gears, Mini Servo, ESC, Motor, 64P Pinion Gear, Battery, Tire & Wheel, Body
Kawada M500WGT-X
Technical Data
1/10 Scale
MADE in JAPAN
Wheel Base: 258mm
Driect Drive 2WD
Ball Diff
Required Items
![BanzaiHobby is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
