Tamiya TA05-VDF etc. Lots of new products in Stock!!
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Now in STOCK!!
http://banzaihobby.com/index.php?mai...index&cPath=18
Tamiya 84132 TA05-VDF Drift Chassis Kit
Tamiya 58467 Castrol Honda Civic VTi - FF03
Tamiya 58464 Suzuki Super Swift Super 1600 M-05 RA
Tamiya 84124 Wolf WR1 - F104
Tamiya 54225 TRF Heatsink Motor Plate - Light
Tamiya 54226 FF03 3/32 Tungsten Ball - 12pcs
Tamiya 54234 FF03 Alum Spur Gear Mount
Tamiya 54236 M05 Front Alum Damper Stay-Blue
Tamiya 54237 M05 Low Friction King Pin -4pcs
Tamiya 54238 M05RA Ball Diff Cup Set - Reinforced
Tamiya 54240 F104 Wheel Stopper - Clamp Type
Tamiya 54247 Aluminium Turnbuckle Shaft 3 x18mm (2pcs)
Tamiya 54248 Aluminium Turnbuckle Shaft - 3x23mm (2pcs)
Tamiya 54249 Aluminium Turnbuckle Shaft - 3x32mm (2pcs)
Tamiya 54250 Aluminium Turnbuckle Shaft - 3x42mm (2pcs)
Tamiya 51425 M05RA F Parts - Upright
Tamiya 51426 M05RA Front Skid Plate - w/ Side Guards
Tamiya 51427 60D Rally Block Tires - 2pcs
Tamiya 42169 VG Ball Diff Grease
Tamiya 42170 VG Diff Plate Grease
Tamiya 42171 620 HC Thurst Bearings
Tamiya 42172 VG Bearing Oil
Tamiya 42173 VG Damper Oil #25
Tamiya 42174 VG Damper Oil #30
Tamiya 42175 VG Damper Oil #35
Tamiya 42176 VG Damper Oil #40
Tamiya 42177 VG Damper Oil #45
Tamiya 42178 VG Damper Oil #50
Tamiya 42179 VG Damper Oil #55
Tamiya 42180 VG Damper Oil #60
Tamiya 84150 TA05-VDF Ackerman Steering
Tamiya 84151 TA05-VDF Ti Screw Set
![BanzaiHobby is offline](https://www.rctech.net/forum/images/statusicon/user_offline.gif)
