CTX, Maxx 707, TB-02R, SRX, XS3 Pro, Speedos, Power Supplies, and more!!!
IRS Rugrat, Maxx 707, TB02R, SRX, XS3 Pro, Terra Crusher, Power Supply, and more!!!
OK, I just moved into a new house and I have decided there are things that I just don't use/need so it's gotta go!
GM V12WXC ESC
No motor limit, it's been used only with Stock motors or in its current chassis, a Mini-T. SOLD
Tamiya TB-02R With tons of extras!
I bought the TB-02R and a used TB-Evo 3 at about the same time. I bought the Evo to steal the key parts off of such as aluminum suspension arm mounts, upper aluminum camber link mounts, front one-way, graphite front and rear shock towers, and more. The Evo actually came with 2 different chassis, the standard 2.5mm chassis and a special SSG lower chassis as well. Asking $200 with KO 2173 servo.
Prolux 7-amp power supply
This is a nice small power supply that will work well with a Pit Bull, Orion Motor Performance Monitor, or a Turbo 35. SOLD
LRP Runner AI Reverse
Basically NIP, included connectors still in place. SOLD
Maxx Racing 707 Sedan
Very low running on this car. It's pretty similar to the TRF 414 or the older FK kits. The car is box stock, asking $125
Hitec SRX w/receiver (Channel 62)
Works well, just no need for it. SOLD
Duratrax Evader ST
This truck was run by my stepson for a few weeks until he lost interest. The stock servo was swapped out for a JR Z270 servo. A lot of aluminum performance hop-ups, heat sink motor mount, Pro-line rear tires, and more. Comes with ESC and receiver, I have the radio somewhere, just need to find it. SOLD
JR XS3 Pro
Just like the SRX, it works awesome, but I have a Z-1. Comes with RS300 receiver (not pictured) SOLD
JR XR3i-
75mhz, asking $55
KO Handheld Programmer for VFS-2000- SOLD
Venom Racing 19T and brushes- SOLD
Tamiya Tom's Toyota Body- $sold
Much More CTX V3.0
It works perfectly except the optical sensor has never worked. I am sure if you just send it into TMM you should be able to get it repaired. sold
MRC RT-4 and RT-4 Pro
2 trucks in one. One engine included, needs to be setup in the truck so that the brake and cluch actuate properly. Asking $75TOTAL FOR BOTH!!!!
Only trades that will be considered would be for an MF2. Buyer to pay actual shipping charges. There will be more to come as well, I just have to look through the rest of my stuff.
GM V12WXC ESC
Duratrax Evader ST
JR XS3 Pro
JR XR3i-
75mhz, asking $55
Much More CTX V3.0
Gary:
Hi,
I'm interested in your KO handheld programer. Please sent more Pics to [email protected]
Hi,
