NEW XRAY T2
#1681
does anyone else think that the countersunk washers on the top deck would cause it to be stiffer than without?? see above pics to see what im talking about. Seems to me the larger area covered by them would make the chassis stiffer.
#1684
#1685
#1686
I remember reading somewhere on this forum that the space for the servo is smaller than the FK'05 can anyboby confirm this?
I dont like the way it looks when half the servo is hanging off the side of the chassis..
I have a Jr Digital servo which I believe is bigger then other company's servo's. I think.
#1687
Originally Posted by Ill Factor
I bought one of the RW racing spurs but it was not a direct fit as none of the wholes lined up. It did have blue numbering instead of red. Are there two different types?
#1688
#1689
#1690
COULD U POST THE PART # TO THE DYNAMITE SERVO HORN?
#1692
Originally Posted by peter_robinson
if you mount the servo to the outside of the servo posts, then a little bit of the servo will hang off the side. however i found a dynamite alum servo horn that is thin and will allow you to mount the servo to the inside of the posts and move it towards the cars centerline about 6-7mm.
Like this? I had to do that last night. I couldnt stand having all that servo hanging off the side, and then having the link at such an odd angle.
I used a GS servo horn tho...
#1693
blue, silver, black, and Purple.
http://www.stormerhobbies.com/cgi-bi...umb=on&smode=0
#1694
The Evicerator
*pokes his head in the door and looks around*
hmmmm....
hmmmm....
#1696
Oh Yeah..The UPS Guy just came in with my T2. As I opened it up there was a pair of Jaco dbl pink and dbl pink/orange foams in the box. Totally was not expecting that!! Speedtech You Rock!
We'll I gotta go. I got a new car to build. It looks like tonight might be a long night.
#1697
#1698
Anybody know brand the foam tires are? A friend told me they are good tires.
#1700
delivery
UPS says out for delivery!!!!!!!!!!!
Can I get to the house before the wife gets home.
Ok excuses for leaving early?
Oh this is going to be an interesting evening at my house.
OH well at least I will have the kit---- if I have to look for new wife.
Just humor: she won't leave but I could be Bobbitized!!!~!
#1701
They are Jaco Foam Non 2-stage. this is the right compound for any carpet.
I think RC America gave these to all of the first kits ordered.
#1702
Originally Posted by lazarus
ALL the kits in the first shipment received the Jacos from what i understand. Speedtech had nothing to do with that. Give the kudos where they belong. Steves a nice guy but RC America is the party to praise., lol
Speedtech or RCamerica please let us know who we should be thanking..
#1703
it was rc america....
#1704
#1706
got mine today. speedtech rc saved us at least $35 in foams(thanks). too bad i can't build it yet,but can't wait.
#1709
foamies? score.
In AUS we get the multi-diff in our kits, but no tyres at all. (you do get rims to mount rubbers on).. The instruction manual has a list of included items, one being a turnbuckle wrench, which we didn't get in our kit either. I think it says antenna mast's are included? didnt get one...
seriously bare bones, for $638 rrp AUS. = $478 USD. expensive kit. But hey, the multidiff is nice.. heh.
As for servo's and horns. I've got a hitec HS-5925 digital servo in mine, full size. The kit doesnt come with a servo horn to suit hitec, luckily I found a blue alloy horn in the box my hitec servo came in, pretty neat. the holes in the servo horn were too small for an M3 screw, so i drilled it out on the drill press and tapped it. It's simular to the purple horn picture above. I used the second hole in from the top (which i measured with calipers to be about the same size horn throw as the factory horns included with the T2). I didnt mount my servo on the inside of the ally posts though. but at least I didn't need shims, which I did when originally trying to fit it all up with a kit-horn and KO servo.
Are people mounting the servo's flat with the chassis? or raising it up a little? curious. I mounted mine down flat, dont want crap getting stuck under there. I also think I'm going to mount my GTX differently, saw some great pics in this thread of some race T2's with GTX's. mounted on their long short edge (opposite soldering tabs)
Have cut my spektrum antenna down to 3.6" as allowed, and made the standard antenna mast holder into an adhiesive post thing which sticks to the chassis with double sided tape (as seen in below pic). antenna fits nicely inside body.. have tested range, no problemo.
some pics. inc pic of car with my nationals body shell from last yr. wanky. hah
#1710
Yep, got the Jaco single stage DPink/DPinkOr with my T2 as well.
Im prepping the chassis and top plates, shock towers... good stuff. Time consuming. Did anyone else flush/relube the bearings? Also... my final understanding of the shock difference between the FK05 and the T2 is shock shaft length? Im looking at swapping my FTTC4 for an FK05, and it has the upgraded aluminum shocks on it... but to my understanding they are NOT the newer serpent ones. If they are compatible i would like to add the aluminum shock bodies to my T2... and keep the FK05 for stock and/or 19T. Assistance? There has been much speculation... but no sure fire answer that i have seen. Thanx.
- DaveW
- DaveW
