3 - MTX3 Cars for Sale
MTX-3
4mm Chassis
3mm Chassis
Titanium Midshaft
Titanium Rear Shaft
Metal Chassis Brace
Metal Radio Tray Brace
6V Battery
Kawahara Roll-Bar
Front Solid
One-Way Axle
Front Diff.
Rear Solid and Differential
Universals Front and Rear
Aluminum Hex Adapt.
Kawahara Pulleys
Lightweight Pulley Adaptors
Metal Brake Stop
Aluminum Brake Lever
Vented Disc
Aluminum/Lightweight Engine Mounts
Lightweight Clutch
Red, Grey, Black Clutch
Silver Clutch Spring
Gold Clutch Spring
Metal Mid-Shaft Block/Carrier
Front 4mm C/F Shock Tower
Rear 4mm C/F Shock Tower
Rear Alum. body post tower
Most of the upgrades are Kawahara.
MTX-3
3mm Chassis
4mm Front C/F Shock Tower
4mm Rear C/F Shock Tower
6V Battery
Kawahara Hex Adapt.
Kawahara Roll-Bar
Universals
Complete other than needing a center belt and I "think" one or two washers for the clutch.
MTX-3
New, never run.
Needs one shock, lower left A-Arm, a couple bearings, and clutch washers.
(This one is "iffy" on the description I will try to get the pieces broken down - it might end up being complete.)
Before I get any posts about the MTX-4, I know, no need to reinform me. These are what I am asking. I will try to post pictures within the weekend.
4mm Chassis
3mm Chassis
Titanium Midshaft
Titanium Rear Shaft
Metal Chassis Brace
6V Battery
Kawahara Roll-Bar
Front Solid
One-Way Axle
Front Diff.
Aluminum Hex Adapt.
Kawahara Pulleys
Metal Brake Stop
Vented Disc
Lightweight Clutch
Gold Clutch Spring
MTX-3
3mm Chassis
6V Battery
Kawahara Hex Adapt.
Kawahara Roll-Bar
Universals
MTX-3
New, never run.
YGPM
I forgot about this thread. Would you believe my digital camera malfunctioned.
Hey man...can you send pics to [email protected]...i like the first mtx-3 u described...really interesed...can you take pics please
Mike
Mike
I might be interested in trading for a Tamiya TXT-1.
Are all of these still available?
Yes, sir.
Scratch that. Drop me an email, and I'll pictures and information on my TXT.
[email protected]
Thanks.
[email protected]
Thanks.
