STOCK motor forum >
STOCK motor forum
STOCK motor forum
Old 10-03-2001, 07:20 PM
porkybmx's Avatar
Default STOCK motor forum
Guys, I mandated that all my club members use stock motors for now. So no I'm in the market for a new stock motor. Help me out and give me some opinons and experiences you guys have had with different motors. Thanks
porkybmx is offline
Old 10-03-2001, 07:45 PM
Trader Rating: 82 (100%+)
mvp's are the hot ticket today. i plan to get one in a few weeks. the may 2001 issue of RCCA tested the mvp and the nos. came out as: (out of the box 128.4 watts @ 12,952 rpm; max torque 180.2 Nmm; max rpm (around) 29700
(after break in 134.9 watts @ 12,738 rpm; max torque 197.5 Nmm; max rpm 29,755
marvi is offline
Old 10-03-2001, 08:51 PM
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
the new p2k2, will be good, the p2k is unbreakable, you either love or hate the gm3....i happen to love it...the mvp is cool too....
Matt M. is offline
Old 10-03-2001, 11:02 PM
porkybmx's Avatar
guys has anyone have any experience with the Orion chrome st stock motor? How do they run compared to other motors?
porkybmx is offline
Old 10-04-2001, 08:14 AM
Cole Trickle's Avatar
I've had my Peak Spitfire for a half a year now. I think it's pretty durable and fast, but I haven't tried the others yet. My next will probably be the P2K.
Cole Trickle is offline
Old 10-04-2001, 08:55 AM
Jack Smash's Avatar
Trader Rating: 35 (100%+)
Cole, what brushes do you run in your spitfire and do you cut them or anything? Also, what gear do you run?
Jack Smash is offline
Old 10-04-2001, 09:15 AM
Pit-racer's Avatar
The p2k is the motor of choice with the mvp running a close 2nd here in so.cali
Pit-racer is offline
Old 10-04-2001, 10:16 AM
kenny's Avatar
Default mvp
MVP gets my vote for best stocker.
kenny is offline
Old 10-04-2001, 10:32 AM
RCTech Member #2
TSR6's Avatar
It's fast... they are just kinda like playing russian rulette... I like my P2K's just because they are still fast & consistant
TSR6 is offline
Old 10-04-2001, 11:04 AM
Ty
Ty's Avatar
Trader Rating: 32 (100%+)
What is the brush/spring combo you guys for a Green 3 to get the most power out of it.
Ty is offline
Old 10-04-2001, 11:18 AM
Gear: I'm running on a small (90 meters) track, which is medium tight. I'm running a HPI Sport2, 48 pitch. 93/23=4,04. The final drive ratio is 8,5 (2,1*4,04).
Brushes: Standard.
Cutting: I've only cut the comms once, that was about 30 packs ago. I'm still using the originals brushes, which I haven't cut. I assume I've run about 30 packs before the first cut.
I'm racing and compeeting in our club. I plan on racing with other clubs this season.
Old 10-05-2001, 11:55 AM
Maybe I should add, I'm using Orions Speedy Drops for about every 5-10 packs.
Just got my P2K.
My Spitfire blueprinted data:
Max 23.011 rpm
8,6 torque @ 16650 rpm
105 watt @ 16650 rpm
62% is the best effiency @ 18595 rpm
P2K:
Max 27.988 rpm
189 Nmm torque
129 watt
72,5%
Hard to wait...
By the way, do anybody know what's the unit for measuring the Spitfire torque?
Old 10-05-2001, 12:39 PM
Jack Smash's Avatar
Thanks for the reply Cole
Old 10-05-2001, 01:55 PM
David Galdo's Avatar
Trader Rating: 15 (100%+)
http://rcvehicles.about.com/library/...gfacts_gm3.htm
David Galdo is offline
Old 10-06-2001, 02:14 PM
Core Creations's Avatar
Trader Rating: 108 (100%+)
I use the GM3s and the P2Ks for touring. I'll use a purple/+ and a red/- on the P2k and Red/+ and a green/- on the gm3, both react very good to 4499 Trinity brushes and make sure to keep the bushings well lubed. Niftech makes a great bushing lube that I put on my bushings before EVERY race. It makes the bushing look like polished brass!
Core Creations is offline
