Best 19 turn / Brush combo??
What is your fastest 19 turn and what brushes do you use?
Chameleon C2 with XXX brushes
Reedy Based 19t with 767's with tips chamfered 3min breakin or aggressive technologies at30s with the same tips purple purple or orion silver's
Reedy Spec 19 - 767 brushes with a hole and orion 135 degree silver springs
aren't those 769's "V"?
Reedy 19t Quad-Mag
767's w/ hole on both brushes Purple spring on (+) and Red spring on (-)
i run reedy quad mad w/ quasars w/ orion 180 degree black springs...just make sure that you breakem in fully than cut and run all day. dont forget to cut the comm every run to make consistant power.....
I thought Quasars are standups
Important questions to ask is what type of track you are running at? Tight technical course, or a high speed track? Run both a Cameleon 2, and a Reedy Quad Mag. The Cameleon seems to work better on high speed tracks, and my Reedy Quad Mag seems to like tight tracks like So. Cal. I stay with a simple setup; 769 brushes on both, and red + green - springs. I do a few other mods to get more horsepower though.
who makes more horse power than me? you cant make horse power with those light springs didnt you get the memo?
The quasar is available in both standup (729) and laydown (766)....
And red/green seems pretty light for a 19t....
Later EddieO
Later EddieO
I've got a Dynasty that rips. I believe it has 769's with two parallel cuts. +Red -Green springs. Great motor for 1/12th. C2 and QM are really strong for touring.
C2 XXX hole in pos/neg brush. cut off edges. purle pos, red neg. cut motor every 20 runs. New brushes every 50 runs.
I just used a stream lined setup in both motors to see how each compared on the track. I don't own a proper motor dyno yet to run spring comparisons. Anybody have any hard data on running stiffer springs? P.S. Didn't get the memo.
Chameleon 2 Pro using 767's with 1.5mm hole on both brushes and modified purple springs on (+) rated at 265 and (-) rated at 245 (using the Xipp spring dyno and Fantom motor dyno)
