crc carpet knife
crc carpet knife
1/12th scale carpet knife with all the parts you will need to start racing.
On car
1 -Novak Atom esc
1 -Airtronics 94145 high speed servos
4 -used 4 cell battery packs
block front end with bearings
custom Battery hold down (helps prevent tweak)
large diff with lightweight axle
extra parts
1-Airtronics 94145 servo
1- pivot plate
1- cross plate
1 - rear bottom plate
1 - rear top plate
1- graphite servo brace
2- spare axles
1- block front end setup complete with steering blocks
2- new style Associated front end with steering blocks
5 - used bodies
1 - new body (silver)
4 -sets Pink Jaco Rear Tires-untrued
3 -sets purple Jaco front tires-untrued
1 -set Grey Rear trued to 47.3 mm(1.862")
2 -sets used Grey rears
3 -sets used pink rears
1 -set used Green Rears 44 mm (1.736")
7- used purple front tires
2- 4201 Diff rings
2- 4132 - Dual 12th Clamp hub-2 + 3 bolt
2- 1393 .020 front springs
2- .022 front springs
2- D-ring diff hubs 1 red 1 silver
1- 1367 Aluminum motor plate
4- Aluminum Hex Ball pivots
6- center springs (silver, gold,blue,copper, red, heavy silver)
1- complete center shock
1-extra shock body
9- sets side springs
3- extra kingpins
2- damper tubes
17- ball cups
10- rear axle ride height adjusters
3- rear one piece links
1- set steering blocks
1-set servo mounts
4- aluminum front end block spacers
2- heavy duty steering linkages
assorted bearings
assorted screws
assorted standoffs
ballstuds
spacers
weight
$300
Like I said everything is here that is needed to go 1/12th scale racing. I do not want to get rid of this but the 1/12th division around here is too hit and miss. Paypal only. I will post pictures of everything.
On car
1 -Novak Atom esc
extra parts
1- pivot plate
1- cross plate
1 - rear top plate
2- spare axles
5 - used bodies
2- 4201 Diff rings
1-extra shock body
3- extra kingpins
2- damper tubes
17- ball cups
1-set servo mounts
assorted bearings
assorted screws
assorted standoffs
ballstuds
spacers
weight
$300
Suspended
how much for roller with servo,
and the used bodies
and the used bodies
i will take one of the airtronics
