Whats the best 30 amp discharger?
Looking for a new discharger . What is your opinion?
That integy zero thirty discharges each cell at 30A then slowly brings it down to zero... bombdiggity!!!
nobody has them!!!!!! thats the one i was leaning towards..
www.speedtechrc.com
He will help as long as Integy is still making them he can probably get them.
Hope this helps,
Stephen <><
JUST GOT MINE FROM BRUCE AT R/C FOR LESS ITS NICE!!!
Anyone knows of a discharger which has a 0.9 volt cutoff for each cell and can discharge more that 5 amps. Novak Smart Tray is too slow.
Spintec
aaron..check out the spintec also. i know its not 30amp.. but it is 35amp discharge and it wont heat up your packs.
gives you the following:
- runtime
- capacity
- energy
- internal resistance (for the entire pack)
- discharge voltage
also has a neat decrystallization process..so it brings your practice packs back to life.
- runtime
- capacity
- energy
- discharge voltage
If you don't got a charger that discharges at 30amps, then buy an Integy Reactor 30, discharge as a pack; has automatic cut off. When it stops, use an equalizing tray. Doesn't make good sense to discharge each cell at 30amps and stop at .9v per cell cause you still need to tray them at lower current to accurately equalize them anyways!
Who has this spintec?
Suspended
Originally Posted by cr250
Is the Spintec discharger still only setup for 6-cell packs? I want to buy one but I own many 4-cell packs as well as 6-cell ones.
