Jammin X1 - so close yet so far
#1786
Well guys ...
After 5 years racing 200mm onroad sedans and 4 months racing MT's now im jumping on the 1/8 Buggy wagon ... with a Factory Team X1 Jammin ...
Any special advice during building ? ... i suppose the buggy will hit my door in about a week or two ...
And about engines ... i will try a STS .21 Team Edition what you think about it ?
thanks a lot ...
thanks a lot ...
#1787
macnkitty2002 Jammin makes one also, here is a link
http://www.jamminproducts.com/x1croption.htm
yamrace I use party ballons, have for about two years with no problems. You can usually get a bag of 100 in four different colors for about 3 bucks.
Tabushi here are some good build tips from Chad Bradly.
http://www.jamminproducts.com/chadstips.htm
#1788
where can i get the steering brace from Jammin? how does it compare to the King Headz one? is it thicker? i also saw that 4mm steering rack, has anybody tried that yet, althought the stock one is perfectly fine.
i have a question about differentials. i have been using the basic setup for about 1/2 a year now, 5K/7K/2K. i want to get more steering, so do i go to a lower weight front diff oil? like 4K? and what happens when you change the center diff oil? thicker and lighter? what happens?
thanks in advance.
thanks in advance.
#1789
Originally Posted by yamrace
Anybody find out which is the best shock boot for the big bore shocks? I am building my first 1/8 scale buggy and don't like the fact that the shocks don't come with boots to cover the shock shalf like the rest of the buggys do.
Mugen shock boots work perfectly. They're twice as thick as the Jammin once and a perfect length.
#1791
thanks in advance.
thanks in advance.
#1792
Also, run the No.1 (Or forwardmost) ackerman hole to get full steering throw. After you've done this and notched the arms, the steering knuckles should touch the blocks at full throw.
#1794
thanks in advance.
thanks in advance.
Giong lighter in the center will make the car easier to drive. Going heavier in the center will put down more power over all.
#1797
It does come with the fuel filter, not sure about the air filter. If I were you, I'd start out with a 3-5-1 setup. Makes the car very neutral so you can adjust other things to get the car to respond the way you want.
#1799
Which are the diff oils that comes with the kit ?
thanks,
