Best Losi JRXS Type-R on R/C Tech
SOLD I seriously think this is the best JRXS Type-R on R/C Tech and I'll tell you why. Its in mint condition and was assembled with care - Nothing stripped or scraped up. Also, it has a beautifully sealed chassis and shock towers that shine like a mirror! This car was only raced a few times on carpet and it really shows.
Extras on the car
Aluminum toeblock, stainless thrust bearing, rear hubs, front steering knuckles, 6 deg, 4 deg, 0 deg caster blocks, various LCD spares - front long driveshafts and an axle, body posts, a-arm, a few spur gears, complete spare diff, tons of steering assembly spares, servo horns, ballcups, ballstuds, front upper a-arms, aluminum hex hubs, swaybars...
Looking for $370 + shipping SOLD(Less than the kit costs new and you will never have to buy a part again!)
Thanks for looking, have a lovely day!
Extras on the car
- Losi one-way
- PRS spur gear mount
- RP-30 tires (Discontinued and hard to find)
- Sway bar
- short front LCD for oneway
- hard foam front bumper
- and many more...
- CF battery tray
- 2 bags of suspension arms
- front upper suspension arms
- New front and rear belts
- Shock standoffs
- New parts to build a front axle assembly - driveshaft, LCD rebuild kit and LCD axle
- front and rear inner hinge pins
- hinge pin pivot balls
- Spool pulley
- 128t losi spur gear
- 2 packages of various O-rings
- Diff screw set
- female ball studs
- 3 packages of shims/washers for various parts of the car
- 2 packages of pins
- Aluminum wheel nuts
- Shock pistons #56
- 2 packages of e-clips
- new ball bearing set
- 1 pair 10.5 lb
- 1 pair 12.5 lb (on car)
- 2 pair 15 lb
- 1 pair 17.5 lb
- 1 pair 20 lb (on car)
- 1 pair 25 lb
- 1 pair 30 lb
- 1 pair 35 lb
will u part out some parts
would you sell just the rolling chassis, if so how much?
PM's responded to.
Not really looking at parting out.
looking for offers.
Would you be willing to post to UK?
I'll ship anywhere in the world.
pms responded
