Tamiya mini cooper
#886
Paul-
Bringing some goodies with me on the 17th...
#888
Originally Posted by Steven Key
... the Finals in CA are going to be a "Hand Out" black can motors WITH a spec Gold Peak 3300 that you have to buy at the event.
Jeff
#889
Jeff- All TCS are free, no event fee. Some classes at the Nats require the purchase of a motor and/or (this year) battery pack. Other than that, no charge-O.
#893
Steve-
I think it will depend on the track. At Trackside & World of Hobbies, I'd expect the RWD cars to be very popular, same with Memphis- all three tracks had pretty enthusiastic RWD contingents that only in some cases took out their FWD cars. As you know RWD can be faster than FWD at Trackside, anyway. And with a 21 tooth pinion, the cars will be faster at the tracks with long straights.
I'll be sticking with my FWD shortie for now.
Later
Doc
Later
Doc
#894
I have a set up question for you Mini experts.
I am running a M03 and the rear end of the car chatters during hard cornering on high traction carpet.
Here is my current set-up.
Front:
Blue short springs, no spacers
Ride height 4mm
60 wt., two hole piston, 4 black O rings as travel limiters
S grips over stuffed with black shaped insert over light grey foam
Black, medium sway bar
Universals drives
TA03 ball diff
Aluminum steering knuckes
Rear:
White short springs, 2mm spacer
Ride height 6mm
40 wt., two hole piston, 4 black O rings to limit travel
Slicks, with black foam inserts
Silver, heavy sway bar
0 degree rear blocks
Any suggestions on how to get the car to go through the corners smoother. The chattering really scrubs speed.
Front:
Ride height 4mm
Universals drives
TA03 ball diff
Rear:
Ride height 6mm
#895
Had an absolute blast running my Mini Cooper for the first time last night at SoCal. Those guys had some retarded fast Mabuchi's. Guess they spend money on motors instead of refills on Viagra.... :-) That's for the razzing last night guys. See you all next Tuesday.
#896
one! try M grip tires or even kit radials. (I've heard they work better on carpet)
is the chatter from the front or rear of the car? does the car over or under steer?
Front:
Ride height 4mm
Universals drives
TA03 ball diff
Rear:
Ride height 6mm
Front:
Ride height 4mm
Universals drives
TA03 ball diff
Rear:
Ride height 6mm
#897
Originally Posted by jw92656
Had an absolute blast running my Mini Cooper for the first time last night at SoCal. Those guys had some retarded fast Mabuchi's... See you all next Tuesday.
Jeff
#898
tamiyarcracer
The chatter comes from the back. It may be a result of too much traction in the rear. If anything the car has a little push.
