MTX4R for sale
MTX4R for sale
I am selling my mtx4R. it has the following upgrades and parts included;
-Kawaharra 3mm chassis installed
-Kawaharra Alloy steering bell crank
-Kawaharra alloy brake arm
-Kawaharra light weight alloy engine mounts
-kawaharra carbon fibre engine cross brace
-kawaharra front alloy sway bar mounts
-standard chassis included New, never used
-Knack 4mm chassis, little use
-front and rear Mugen CVD’s
-front Mugen multidiff
-Skyline alloy top arm supports
-Skyline alloy front diff supports
-Skyline alloy front bearing layshaft block
-Skyline ally rear baulkhead support
-Skyline alloy sway bar holders
-5 Star racing alloy top deck supports
-5 star rear alloy shock tower and diff brace
-5 star racing lightweight pulley holders installed (full set)
-Knack racing 0.8module rear diff gears
-knack rear blade type sway bar
-KM Racing carbon fibre battery tray (modified to lower tank by 3mm.)
-KM racing lightweight flywheel installed
-MTX3 Prospec brake disk
-MTX4R rear camber plate
-rubber belts all round (low friction type)
-2 degree steering knuckles
-double thickness rear shock tower
-titanium light weight screws throughout
-titanium pivot balls
-alloy wheel hex hubs
-full set of light blue and dark blue springs included with kit.
-1400mah intellect pack
car is pictured with servos, receiver and transponder.
These items not included, show for display purposes only.
Screws, and washers for servos, and all other elements
pictures are included. Car is not pictured with Kawaharra
engine mount, or with complete Mugen clutch THESE
PARTS WILL BE INCLUDED IN THE KIT.
Spare parts included
Below are new in packet:
-Mugen Black clutch shoe
-Mugen yellow clutch shoe two packets
-Mugen Grey clutch shoe (3 packets
-Mugen red clutch shoe
-Mugen 24 tooth pinion
-Mugen 18 tooth pinion
-Mugen front belt
-Mugen 2 degree front uprights (steering knuckles)
-rear lower hinge pins
-front lower arm
Parts out of packets
-side belt
-4 belts (mix of front and rear 1 belt is rubber low friction type Never used)
-2 sets of diff gears to construct diff
-various diff parts (cases)
-a complete diff with 30,000wt oil installed
-rear wheel hub knuckles x 3
-front steering knuckles x 4 MTX4 edition
-59 tooth spur x3
-58 tooth spur x1
-53 tooth spur x1
-Rear bulkheads both sides
-front bumper lower and top sections
-2 speed jousing
-flywheel Never used
-3 rear carbon fibre camber link inner plates
-3 clutch bells (2 with different pinion gears, one no pinion gears)
-Mugen rear 2 speed layshaft
-Huge amount of spare pulleys and mounts
-misc plastic and metal parts
Well looked after car, purchased for QLD state titles.
used for event and 3 race days after that. small modifications
for added strength and race readiness already done. Electronics
not included, although battery pack IS included.
Must sell before wednesday. quick sale required. Pictured with no sidebelt, but this is included
asking for $600 with parts included. No low ballers no time wasters
-Mugen front belt
-front lower arm
-side belt
-59 tooth spur x3
-58 tooth spur x1
-53 tooth spur x1
-2 speed jousing
nah man, it's got shit quality plastics and wood screws
i'm considering the xray, but it's a pricey ride that's for sure. I also hate how not many companies make hop ups for it. I've found a 3D CNC company here in OZ that might be able to make some parts like alloy front lay shaft mount and a few other things. The 3 racing stuff looks shyt and the quality is probably close to this as well
Bump for a top bloke and i say this to who ever buys it, you will have the best looked after cvds, car is always well looked after and cleaned regularly. you ever asked what the B stood for in the TomB? BLING BLING BABY.
