xxx-nt ad2 and schumacher havoc
If interested call me and I will tell you everthing that comes with it.I also have things on the way from ebay that aernt in the pics.Alot of stuff.7654505781 is my number and my name is Torrey.I'mm asking $600.00 plus shipping or I'll trade all for another 8ight.I'll have WELL over that with all the things come.The xxx-nt has not been ran since all the new parts have been installed.They are both rtr.
AD2
HOW MUCH FOR JUST THE AD2
Well let me start naming off all the things that come with this.The two trucks which are rtr.I have four sets of tire and wheels.2 on road and 2 off road.ad2 chassis(new)front graphite arms(new),Front graphite bulk head(new),Front graphite shock tower(new)2 graphite rear shock towers(1-new),rrp diff gear(new)unpainted ad body(new),graphite center chassis brace(new),rear graphite arms(new),brake hub and gear(new)all is installed.I also have the qc axles not installed yet but will be.Waiting for the ad2 rear pivot block,ad2 reae arms,bushing and screw set and the qc rear ad2 wheels and tires and the ad2 front wheels and tires.It has a o.s. .15cv-x engine with about 3/4 of a gallon through it and I have a drake.12 engine on the way that was just broke in.It will come with it uninstalled.I have the lunsford titanium turn buckle and hinge pin kit coming(lun4065).I didnt know if the hinge pin kit i bought would work for the inner hinge pin on the rear so I also bought the tri-nitride inner hinge pins for that.I have the white ball cups coming also(losa6015)It also has a painted body and a bunch of rear and front shock towers,front and rear arms,pivot blocks,drive shafts and a new brake disc.I have a new venom 1200mah reciever pack never been charged and a 2200mah reciever pack.It has a new thrust bearing.losi roto start.a bog of bolt and a mip heavyweight flywheel and 2 pinon gears.New ad2 battery box and reciever cover.This truck is going to be brand new.It also has new in package parts like shock rebuild kits,tie rods and ball ends,manifold gaskets,etc...It has the jrxr2i radio and jr125 reciever.The havoc has the same radio set up and it has the thunder tiger.28 engine.New shock shafts and shock ends all new in packages and 23mm adapters with proline wheels and tires and the stock wheels and tires with 2 new in package tires.I always took really good care of these two trucks.After run oil,clean,air filter oil etc...I just changed all the shock oils in both trucks.The havoc needs a new body because it likes to flip back evertime you take off or in the middle of driving at a certain speed the whole front end comes up.These trucks are a-1 and I probably left thing out that come with this package but if you have any questions let me know thanks for looking.The reason I'm selling is because I just got an 8ight for christmas and I need to get it ready for crcrc next month.
Oh yea and the ad2 was a xxx-nt that I converted to an ad2.Everything that an ad2 has this has.The reciever is removed on it because i am waiting for th ad2 batt.box and reciever cover then ill put it back on and I also have to install a new venom temp.gauge/fail safe that's not in pics.I'll post one in a minute
