Team Losi JRXS Type R
The car has been used 1 race day and 2 practice days. The roller will come with a JR8800s servo and lots of extra parts including NIP caster blocks(6 and 8 degree), aluminum hexes (1-.165, 2-.195, 1-.225), aluminum 1 degree mount, 1 sway bar set (on car), NIP package titanium ball studs, Parma Mohawk body (LW) and a set of Parma Magentas around 58mm, etc. I will list everything that will come with the roller this evening and post pictures as well. Asking $325 shipped in the lower 48. Electronics in pictures not included except for the JR8800s servo which is part of the deal. Car has only been run on carpet. There are no scratches on the bottom of the chassis.
- 6 degree caster blocks on car
- 1 degree aluminum block on rear of car
- Titanium ball studs .38 on front camber link
Parts list
- JR8800s servo
- Parma hard bumper
- Parma Mohawk LW (in pictures)
- Parma Magenta tires (on car about 58mm)
- 1 - .165 hex pair (on rear of car)
- 2 - .195 hex pair (1 pair on front of car)
- 1 - .225 hex pair
- 2 degree aluminum block
- Sway Bar Set (.04 on front of car) LOSA4252
- #4 Narrow washers LOSA6215
- 10mm pistons #57 LOSA5342 (on front of car)
- NIP Losi Steel Ball Studs and ends, HD 4.40x.250 LOSA6026
- NIP Plastic ball cups short LOSA6010
- NIP 1/2 Graphite Rear Hub set - LOSA9852
- NIP 2 pair - Rear Hub Carrier 0 degree - LOSA9865
- NIP Front Caster Blocks 6 LOSA9763
- NIP Front Caster Blocks 8 LOSA9764
- Springs - 30 (on car), 25, 20, 17.5 (on car), 15, 12.5
- NIP 42T Spool Pulley and Plate LOSA3325
- NIP #4 and 1/8" Hardened Washers
- NIP Front Suspension Arms LOSA1217
- NIP Rear Suspension Arms LOSA2223
- Pivot Mt and Shim Set LOSA9668
- NIP Shim set 3/16, 1/4, 1/2 LOSA6230
- NIP Titanium Turnbuckle 14.6x3 LOSA6532
- 2 NIP Short neck Titanium Ball studs .25" LOSA9948
- NIP Short Neck Titanium Ball studs .38" LOSA9949
- NIP Carbide diff balls 3/32 LOSA6951
- 4 degree caster blocks
Parts list
- JR8800s servo
- Parma hard bumper
- 1 - .225 hex pair
The car has been used 1 race day and 2 practice days. The roller will come with a JR8800s servo and lots of extra parts including NIP caster blocks(6 and 8 degree), aluminum hexes (1-.165, 2-.195, 1-.225), aluminum 1 degree mount, 1 sway bar set (on car), NIP package titanium ball studs, Parma Mohawk body (LW) and a set of Parma Magentas around 58mm, etc. I will list everything that will come with the roller this evening and post pictures as well. Asking $350 shipped in the lower 48.
Don't hesitate to buy from Apex.... he is a great guy... why is the Losi for sale anyway?
