THD Products for XXX-S, XX-4, XXX-4, XXX-CR & TCR
Hey! Just wanted to let everyone know that I have plenty of these available as of right now.
The 6061 Aluminum Sleeves are for the Losi Molded Outdrives #A-3097. Trinity use to make some a while back, but I think they are pretty hard to come by. These also have a couple holes in the sides for a glue-spot to help keep them on (I think the Trinity ones had an issue w/staying on). Myself and a few others have been running them on our XXX-4's for a while now, and I think there are even one or two that have put them on their 2WD buggies. I know they have saved me from breaking a lot of outdrives! If you're still running the steel outdrives, that's cool, but the molded ones with my aluminum sleeves weigh about half as much. When you're running stock truck or buggy, that reduction in rotational mass should be a big advantage.
***NEW PRICE*** $15.00/pair + shipping
The Screw Kits are for replacing the Losi Kingpins #A-6235 that captures the plastic spindle carriers in the front arms of the XX-4 & XXX-4, they may also work on the XXX-S if you’re into on-road. I know everyone has done it, you barely graze the pipe or wall with your 4WD and the spindle carrier gets ripped from the arm. In two weekends I probably had that happen to me 5 times total in practice and qualifying. It’s even cost me a main before. After I installed them, it hasn't happen to me since
I sell these for $4.00/set + shipping
Both packages include instruction on how to install the parts properly, so no need to worry about messing up. You can PM me on here, or send me an email at: [email protected].
Thanks for checking out what I have to offer. Hope to hear from you!
Derrick Hochgesang
Testimonials:
tech user ms3 Chris:
"I have used these sleeves for almost a year now and have had no breaks or issues with them at all- As an experienced 4wd racer with numerous wins and podium finishes, I can say these things work great. They weigh virtually nothing and I have not noticed any decreases in performance. By using these, it is one less thing to worry about breaking while using the plastic outdrives on the 4wd."
tech user garrettsdad:
"I ordered both the screw kit and sleeves, very high quality, and the shipping was Faaasssst! I would recommend these to anybody!"
Derrick Hochgesang
Testimonials:
FYI...
I just weighed a pair of steel outdrives, and a pair of molded outdrives with aluminum sleeves to get the exact difference in weight. It was huge! The steel ones weighed 21.89 grams, and the molded ones with aluminum sleeves weighed 7.35 grams!
I have (13) pairs of outdrive sleeves left. I will sell them for $12.00/pair shipped to anywere in the lower 48. Let me know if you are interested.
Derrick Hochgesang
THD Custom Products
[email protected]
Derrick Hochgesang
THD Custom Products
[email protected]
