The "Official" ask McGoo!
Ask him about Painting!
Marc, what do you think about my all yellow scheme?
How many bodies do you do a week?
What would you suguest a new painter start out with in terms of media... Pactra or Faskolor.
I am a faskolor guy - I know a few painters use Pactra (Roly/WED Jim) - and their bodies look great! ShopUFO only uses Faskolor and his stuff is killer as well.
I like Faskolor b/c it is waterbased - thus much easier to clean and also no smelly fumes. I have been playing with some pactra and I really like some of the colors you can get with Pactra that you can't get with Faskolor....
So - both are good - Faskolor is less toxic
BUT with BOTH - USE A MASK!!!!
See, I knew there would be a good reason to start this thread. Already useful info!
Is it true that a new and nicely painted McGoo shell makes you run faster and stay off the boards?
Chris
Chris
For single action - your best bet is going to be with your PSI on your air compressor. When i first started out I was using cheapo dual action. I was using way too much air than what I needed. My brush always clogged up and it was a MAJOR pain in the you know what.
Dual action will make your life much easier as a painter. Single action you seemed to be locked into one setting. If you are wanting more paint to come out a little faster and you are covering a large area, one thing you can do (if your brush allows it) is to just pull back the needle a touch and then lock it in place. I am not sure if a single action can do that - but what it does is "open up" the nozzle to allow for more paint to come through. Don't pull back too much on the needle - JUST A TOUCH!!
Hope that helps...
