My Misbehavin' RC Speed Results for Team Losi 8ight.
Hi all I just did the speed determining test found on Misbehavin' RC and got the result of 60mph exactly with my Team Losi RTR 8ight. It has the Dyamite 4 shoes clutch with gold springs, a chrome OFNA single chambered pipe, and everything else is 100% stock. Is this a good speed? Also since it put my engine under such strain in my opinion I did after-run after it cooled down with the piston at bottom dead center. I have one question. What will it do if I take out the copper spacer under my cooling head?
I doubt your buggy went faster than 42 mph with a stock 14 tooth clutchbell. The stock engine just simply doesn't turn the RPMs necessary to hit 60 mph.
Dude, I have Byron 30% fuel, a cold plug, a perfect tune, and a pipe that is a match made in heaven for my pipe. I promise to you that I measured out EXACTLY 100 feet and did over 10 time trials averaged those and then put them into the calculator on Misbehavin which is correct. How can you not beleive scientific precise results?
for my engine! sorry.
One of the Mag reviews clocked the 8ight RTR at 47 mph using a radar gun. I cannot remember which mag it was. This sounds more realistic to me than 60mph. Might want to check over your math again.
Guys I know I went 60 so I don't care what you think.
Ok, ok I may have rounded it up from 57mph
8ight RTR
I have an 8ight RTR. I also run 30% byrons here (on the 427) and have run about 1/2 - 3/4 gallon of fuel through it so far. With everything stock (besides the four shoe clutch), using a Stalker Police issue KA radar band, my 8ight hit a top speed of 46 mph. I did multiple trials with different high speed settings on smooth concrete. You must have a great tail wind pushing you up to 57 mph.
it wasnt windy... idk guys i will make a vid of it to prove to u
why would you use 100 feet? 60mph is 88 feet per second
100 feet is used to get a relatively clean equation for the spped trap. and no its stock gearing other than diff oil. I am of to bed and will answer and messages tomorrow, night all!
100 feet doesnt go into 5280 very cleanly lol
