3 FK05's plus parts
3 FK05's plus parts
FK05 Roller will sell for $120.00 each.
2.5mm Ran on Carpet (Plus 3.0mm chassis) 3.0mm chassis that has a cracked and glued nose.
2.5mm Ran on Asphalt (Plus 2.0mm Chassis) 2.0mm chassis has no scratches on the bottom the battery slot is kind of ugly. I didn't do it. They do sit very nicely in the slots however.
I have One Wide Top Deck that is cut down the middle (see Picture) and has no Stand Off Mounts. (I ran this on the car All the Time on rubber tires.) Here is what I did with it this season. http://www.nwic2006.com/points/nwic-points.htm It is Dialed. I have two standard Wide Top Deck. Can also modify this for rubber tire. All my setup’s are on the Xray site under RedRocket.
All cars will come with a diff front and rear. They will be double checked for smoothness or rebuilt. All bones will be straight. If one is bent I won’t replace it but will send a straight one with the car. No guarantee on the blades. (The new one suck.) I will not go through all bearing individually but I think that there is a bad one in the car I will send a good one with the car.
Parts have been divided among the two cars. If you don’t want any of the parts, the car alone is $100.00.
Want a Multi Diff? I have a few, Very little use on them. Add $40.00
Need a Speedo? Quantum 2, very little use, less than half a season. $100.00
I have a lot of arms and assorted parts that I will just split up between the 2 cars. Basically half of the parts in the picture go to each car. I took picture with all the spring but I am gonna be keeping the softer one. If you are interested in Foam and want the stiff springs let me know.
Anders Hagen
RedRocket
Anders Hagen
RedRocket
More Pict's Either Pm me or I can be emailed at
[email protected]
Bring offers. will negotiate.
Need to sell.
[email protected]
Need to sell.
hey dude... i like the 3rd chassis across and wud like to know where you live... and how much for a roller....?
