Gm Brushless Systems
There seemed to be alot of talk about Gm Brushless stuff in the "New Orion Brushless" theard so i thought i would make a thread for Gm stuff.
Also i have a problem with my system, ill see if i can explain it. When i turn on the car and have it sitting there it wont throttle. But if i turn the spur and give it a little push start sorta thing it goes. But then when i stop again it doesnt go and i have to push it again. And also sometimes when i stop it works fine. I have worked out that it only doesnt go when the rotor is in a certian posistion. It is when the speedy light is green. When it is red or red and green it works fine.
So if you could help that would be great.
Andy.W
Andy.W
the stuff is the same only other label is what i heard ... yas SHAME ON YOU ORION
Andy.W
Andy.W
Originally Posted by moonman
Could it have something to do with the sensor/sensor cable? Try disconnect it and test it without sensor.
big_boss - I tried doing both of those things and still no go
Also does anyone know how to connect your speed control to the computer so you can use the Genuis software you download from Gm website?
Andy
what i heard is that they re-programmed it .. wich gould take long if ya have NO experience in brushless
and working with hardware you didn`t design yourself ...
just look @ CC mamba max ... that did thak some time too but then they where the first to bring some real stuf out and it`s PERFECT !!!
and they already had over 10 years of brushless experience 1!!!
The system should still run without the sensor cable. We ran at the Euros with the sensors disconnected in the rain. You can sometimes get problems with the cable. I have had this happen. So if you switch everything off, disconnect sensors then switch on, it will attempt to run without sensors.
GM GENIUS 95 Manual
Hi can someone send me a copy of the instruction manual for that speedo, I lost mine.
Thanks in advance
Thanks in advance
It's like saying the Fantom V2's are the same as Orion V2's.....
Both the motors and speedos are different.
I have tested them both and you will notice the difference on the track!!
Andy.W
Andy.W
Hey,
I still havent worked out my problem. I think it may be the motor only thing i can think off. Ill try another see what happens.
Andy.W
Andy.W
My speedo works with brushed motors so maybe the problem is related to the 4.5 motor. It doesnīt work either with sensorless or with the sensorcable connected.
