Castle Creations Mamba/MM/MMM FACTORY Q&A thread!
#631
Tech Legend
Trader Rating: 51 (100%+)
I finally got out anf ran my Mamba &7700 motor HOLY!!!!!
but the down side is someone there at the track mentioned that the mamba wasnt legal for ROAR races... why??? is it case of the good ole boys club?
i really dont want to change systems...
Will the software install onto a PDA??
#633
Tech Legend
If you only knew how much they have going on. Don't forget they are huge into 1/18th scale and just as big into planes and helis to.
#634
brian, things still workin good w/that speedo drivin ur hot brushed stuff in the schuey?
R
R
#635
Tech Legend
#637
so do like alot of us do and dont do roar races.
if we where in Amsterdam it would be fine.
#638
Tech Legend
CRASH how are you making out with the MI3 and the one way setup?
In I think 2 or 3 weeks I will be running my brushless 4600 and 6900 motors at the ORL2 points series race. Will be interesting to run brushless motors vs running my Mamba Max in brushed mode. Should be a fun experiance. Might have to order the 5700 motor to complete my setup. No need for the 7700 in my stable right now as it is more than likely faster than I can drive anyways.
#640
Later,
#641
#642
Exellent...my buddy is also looking to test the MM with the LRP Vector BL 4.5 motor...if anyone else has tested them, would you be so kind to post what you have found out? It'll be nice if that combo works nicely, since the LRP Vector motors are 169g, as opposed to the Novak 189g, and CM36 7700 motors are 197g, according to towerhobbies. 30g less in motor weight is a big help in the power/weight department, as well car balancing. I'd sure love to see Castle Creations come up with BL motors for TC racing that are lighter and with a ribbed can for even better cooling and less weight to hopefully drop it to the 175g range, at least..
#645
