FS: 1/8 Scale Ofna Colt, Starter Box, JR XR3 FM Radio Tons of Parts
OFNA COLT 1/8th Scale RTR Nitro On-Road Race Vehicle
For sale today we have a 1/8 scale Ofna Colt. This car is used, but in very good condition. The engine is a .21 Ofna Force, with plenty of compression left. The radio system is an old style JR XR3 75mhz FM radio. The steering servo is a JR NES-4721. The throttle is controlled by an Airtronics 94102 servo. It includes a Dynamite 5 cell 600 MAH receiver pack. It also has a front one way, a purple C-Vec pipe and a Motorsavers airfilter, and an extra set of new tires. The car is in GREAT shape. The parts are all still in great condition and the car has been well cared for. It looks amazing for an old Colt. There are minimal scratches on the plastic parts and everything still works well with no binding. The chassis does have some scratches on it, but with an on-road racer like this it's to be expected. There is one missing screw from the engine mount, but the screw is of standard size and easy to locate. If I find a screw to fit I will install it here before it gets shipped. The radio was literally JUST tested by me and everything works well. The servos still have plenty of power to move the linkages and everything works without hanging up. This car should still start right up if you put a glow ignitor to it. The engine is bump start only, but we can get to that in a little bit. The short list of what's included is below...
OFNA Colt 1/8th Scale Parts
-Ofna .21 engine> Plenty of compression left. Should start right up!
-MotorSavers air filter> Still clean and oiled
-JR XR3 75 MHZ FM radio> Completely ready to run! Tested and in good workign condition.
-JR NES-4721 Steering Servo> Works GREAT and steers nice and fast!
-Airtronics 94102 Throttle Servo> Works GREAT also!
-CVEC Twin Stinger Pipe> Anodized purple, no damage, looks great!
-Front One Way/Rear Diff> Great condition, both work extremely well. Very smooth.
-Purple Threaded Aluminum Shocks> Still hold oil. Great condition, NO SCRATCHES!!!!! Like Brand NEW!!!!
-Dynamite NiMH 600 MaH 5 Cell Reciever Pack> Works and still holds a great charge. This completes the RTR package!
-GREAT Looking Custom Lola Body> Great Condition!! Raced several times but no flips. Paint is still like new and not chipped. NO CRACKS!!!! Slight tire rub from other cars on the track.
-All Original Manuals> Great Condition. Assembly and Instruction Manuals in good shape.
OFNA Parts!!!!!!!
Qty--Part #-----Description------------Retail price
(2)--64230---Spring,Quick change lever--4.95
(2)--64490---Front castor spacer 6 pcs --3.95
(2)--61682---Silicone seal .15 engine-----3.95
(2)--61912---Throttle linkage kit---------7.95
(3)--62647---47T Spur Gear-------------5.95
(1)--62648---48T Spur Gear-------------5.95
(1)--62643---43T Spur Gear-------------5.95
(1)--62644---44T Spur Gear-------------5.95
(1)--64010---52T timing belt pulley------5.95
(1)--64770---Screw Bag----------------9.95
(1)--61697---Engine Mount, Picco-------9.95
(1)--64510---Front upper pivot pins-----5.95
(1)--64570---Front inner axels 4wd-----11.95
(1)--64520---Front lower pivot pins-----5.95
(1)--64022---3x19.8mm pin 4wd---------0.95
(2)--64270---Rear lower pivot pins-------5.95
(3)--64551---11mm C-Clip 4wd-----------1.95
(2)--64210---Rear quick release levers----9.95
(1)--64430---Belt Pulley 16T 4wd---------3.95
(2)--64220---3x16.8mm pins 4pcs---------3.95
(2)--64300---Rear drive shafts 2pcs-------13.95
(3)--64620---Front drive shafts 2 pcs------13.95
(2)--88104---Rear Wheels blk 51mm--------5.95
(2)--88103---Front Wheels blk 51mm-------5.95
(2)--64560---Belt pulley 24T 4wd----------3.95
(2)--64100---Belt Pulley-------------------3.95
(2)--64140---Belt Pulley-------------------3.95
(1)--64450---Front Belt 4wd---------------11.95
(1)--64460---Middle Belt 4wd--------------12.95
(1)--64480---Front upper arms 2pcs--------9.95
(3)--64590---Front steering knuckles-------13.95
(2)--64500---Front lower arms--------------9.95
TOTAL---------------------------387.74 Worth Of NEW IN PACKAGE PARTS!!!
A N D . . . . .
(4) BRAND NEW FOAM TIRES!!!!!!!!!!!!!!!!!!!!!!!! $50 Worth Of Spare Tires! NEVER RUN!!!!
Asking ONLY $350 Or Best Offer. PM FOR SHIPPING INFORMATION!!!!! PRICES VARY DEPENDING ON YOUR LOCATION!!!!!!!!!
OFNA 1/8th Scale Super Starter Box
This OFNA 1/8th scale starter box was originally sold for $100 new in package. This starter is in great condition and comes complete with a 12V gel cel battery, original box, and original instruction manual. The blue paint scheme is still in good shape although there are scratches on the starting surface from the OFNA Colt listed above. The starter wheel is still in great shape with plenty of material left. The motor is huge and will start just about anything out there. It has side charging jacks, a battery meter, glow plug jacks (Does NOT include glow plug wires), glow plug checker, and plug adjustment screw. The starter's motor and switch has been tested and works great (Very smooth and quiet) but the glow plug ignitor wasn't tested. We couldn't test it without the required plug wires. Even without the wires this starter box is a great deal.
Ofna Starter Box
-12V Gel Cel Battery> Still works and holds a powerful charge.
-HUGE motor> Great shape, works well. I was amazed at how powerful and quiet this motor is.
-Great condition frame> Still has the original paint with minimal marks. Starting surface is scratched but it's unavoidable.
-Does NOT include glow plug accessories, although the power leads, adjustments, and jacks are all in place and assumed to be in good working order.[/b]
Asking ONLY $60 Alone, Or FREE With The OFNA Colt
Pics are Below
OFNA Parts!!!!!!!
A N D . . . . .
Ofna Starter Box
Pics are Below
Pic Added! I also found the screw for the engine mount. Now ALL 4 SCREWS ARE INSTALLED!!!!!
Up it goes. Let me here your offers
Any offers
TTT
up it goes
New price for EVERYTHING. I will break some of this up, let me know what you want.
Anything, please offer anything....
ANY OFFER?!?!?!?!?!?!!?!?...Please help me sell this
TTT
Alright..... $300 + shipping and you get...
JR FM 3 CH Radio
Ofna Colt
Ofna 8th Scale Starter Box
Fast Engine
Boag Of Parts
Spare Tires
Manuals
And More!!
$300.... It's yours......
JR FM 3 CH Radio
Ofna Colt
Fast Engine
Boag Of Parts
Spare Tires
Manuals
And More!!
