Power Supply Caddy - NIP
-Power Supply Distribution Box- NIP
Tired of paying $50+ for the Team MuchMore units? Then this is what you need. Built for RC racers by an RC racer.
Having built them in my local market for a while I am now expanding the service. This ultra compact 4"x2"x1" unit features four outlets, 2 constant on and 2 at the control of on/off miniature 10A toggle switches. The switches gives you easy access to turning two of the outlets on or off and work great for motor coolers, fans, dischargers, and more. Switches have LED's indicating on/off position. All blocks are constructed using 12 inches of 14 gauge silicone wire and UL approved switches. Units come with banana plugs installed for connecting to power supply.
Only $29 shipped USPS to the lower 48. Paypal only!
Future units will be made using a 5"x2.5"x1.75" enclosure with LED's mounted on top. Customize your box by choosing between Red, Green or Yellow color on your LED's. Screws securing the lid can also be colored in Red, Purple, Blue, Black or Yellow.
Other customizations like; longer cables, more outlets, adding LED's as well as using Ultraviolet super bright LED's can be done for an added cost.
PM with questions!
PM with questions!
To the top again. I have 2 4 outlet units available and 1 3 outlet box. Switches vary slightly. The ones not pictured here have push button switch (3 outlet version) or black toggle switches (4 outlet version).
Future units will be made with illuminating rocker switches.
