Tamiya TA05 Touring Sedan >
Like Tree68Likes
Old 05-27-2007, 12:56 PM
  #7681
Dan the Man's Avatar
Trader Rating: 41 (100%+)
Ah, didn't see that. *slaps forehead*
I'm sure he'll get back to me then
Dan the Man is offline
Old 05-27-2007, 04:33 PM
  #7682
AWK
AWK's Avatar
Anyone have a good base setup to offer for their TA05 at the Tamiya track? I need to get a jump testing next week, and any help I can get would be great!
Going for GT2 this year with a Co27 motor. Any tips on damper oil, toe blocks, gearing and motor brushes would be awesome!!! Thanks to anyone who can help. I am kinda scrambling to try and make the TCS race in June.
AWK is offline
Old 05-28-2007, 06:08 AM
  #7683
raffaelli's Avatar
Trader Rating: 13 (100%+)
Originally Posted by Solara
Depends on the offset of the rims....I was using the "R" outdoor for mod foams and using NITRO car's foams tires (Ellegi/Nitro shoes...etc) With 0mm offset 26mm front rims (typical front rims for most Nitro TC except Kyosho and Mugen)...I have to add about 2mm shims after the standard 5mm hex to clear the steering knuckle's (the arm of the knuckles are the problem, not the upper link ball studs or other parts)...again, that was only the typical front Nitro TC 26mm wide rim...
28mm Electric TC foams might not fit unless you are using the +2mm off set rims...which I am not sure there is such things. I do have 28mm foams from GQ and Parma, but I was not planning to use the "R" for indoor foams so I have not try that...
Thanks. GQ is what I will be running.
raffaelli is offline
Old 05-28-2007, 06:09 AM
  #7684
raffaelli's Avatar
Originally Posted by Core Creations
If you want to use foams go with the stock 05 suspension. You can fit any 28mm carpet foam made with no clearence problems. No special wheels, hubs etc needed. And it's much tougher than the lightweight suspension.
You can use the lightweight suspension but you must use some HPI Pro 4 knuckles and carriers to get clearence.
The stock 05 suspension is what comes with the base kit?
Old 05-28-2007, 06:43 AM
  #7685
Core Creations's Avatar
Trader Rating: 110 (100%+)
Yes, that is the preferred suspension on carpet..even for the 415.
Core Creations is offline
Old 05-28-2007, 08:17 AM
  #7686
I have planned to buy the optional light-weight tub for my TA05-R.
Can anybody tell me whether this chassis is conductive as it has carbon fibers - I mean if I use side-by-side cells, will chassis cause a sort of short-circuit?
If yes - how have you made insulation? I don't want to wrap whole battery in a shrink because it disables balancing discharging...
TommyW is offline
Old 05-28-2007, 08:19 AM
  #7687
Trader Rating: 17 (100%+)
Yes it will cause shorting (seen that happened before...)
Solution (from the exact same user)...use electric tape and taped the bottom of each cell....ugly, but works.
Solara is offline
Old 05-28-2007, 08:54 AM
  #7688
Default Legal GT2 bodies at the Nats
I'm getting conflicting stories about which bodies will be allowed in GT2 at the Nats....
Some of the guys I race with insist only 4 door sedan bodies will be allowed (Audi and Benz).
TCS home page says 4 AND 2 door sedan bodies but no sports car bodies. It doesn't go on to explain or list which is which.
Some posts in this thread say that the 350z, Lexus, Porche and Skyline R34
are legal.
Someone please explain. I'd like to get some bodies ordered so I can get them to my painter.
qwkpony is offline
Old 05-28-2007, 11:50 AM
  #7689
lbckevin's Avatar
Trader Rating: 107 (99%+)
In the regional races you can run any body except the Subaru Legacy.
Last year in the Nationals:
GT1- any body except Subaru
GT2- No Ferrari or NSX. or Subaru..alot of different to choose from
GT3 - same as GT2
lbckevin is offline
Old 05-28-2007, 09:30 PM
  #7690
Turbonium's Avatar
Trader Rating: 27 (100%+)
The GT-1 class will be allowed to use any sports car or touring car body as usual.
The GT2 class will be limited to 4 door touring car bodies and 2 door sedan bodies only. Sports car bodies are not allowed. Same TCS Finals rules as 2006 apply.
lifted straight from the TCS Nats race rules...
Turbonium is offline
Old 05-29-2007, 12:27 AM
  #7691
ah_DaN's Avatar
Solution to TA05 plastic chassis from static electricity:
Source:
http://translate.google.com/translat...&hl=en&ie=UTF8
ah_DaN is offline
Old 05-29-2007, 01:22 AM
  #7692
Source:
Very nice - gotta try. I actually soldered wire to screw-heads because I don't want to put anything extra stuff under screw-head.
I think it is good idea to prepare screws with solder when they are not attached in their places to prevent melting plastic parts... ...attaching wire is quick and easy after screws have been tightened.
TommyW is offline
Old 05-29-2007, 05:02 AM
  #7693
sosidge's Avatar
My version of the fix. Using cone washers and round head screws.
More at www.sosidge.com
sosidge is offline
Old 05-29-2007, 05:18 AM
  #7694
Wow....I guess I got lucky with no problems...ever???
Old 05-29-2007, 05:51 AM
  #7695
tc3team's Avatar
I find it strange how different brands of car with a similar spec do not have this problem?
Maybe as time passes and the new kits get used more they will loose their ability to produce the static electricity...
or maybe it's the carpet causing the problem?
tc3team is offline
