New charger?
New charger?
I am also interested in buying a DC charger about 160$.
I was thinking for LRP pulsar competition 2 DC peak charger.
Well?
Well?
Check out the Duratrax Ice too, sweet charger and it goes for about 130 (less if you have Tower coupons!)
If you don't need a discharge feature look at the APS 3 IN 1 Dyno-Charge at www.speedtechrc.com It is really the best charger for under $150.00 unless you apsolutely need a discharger which I am finding I rarely need from my charger as discharge trays are better equipt at it and they all take the amps from each cell insted of from the outside two.
Just my two pennies...
Stephen <><
Stephen <><
If you deadshort your packs the APS Dyno-Charge may have troulbe detecting the battery and allowing the charge cycle to start...apparently it senses the voltage of your pack to determine it is hooked up with the proper polarity....
Just an observation from a friend of mine who is using one of these..there MAY be a way around it...
Hmmmm........
starting a charge with dead shorted packs is easy all you have to do is set the charger to motor run and hit start for 2-3 seconds gives the pack just enough to bring the voltage up from zero. The original GFX software was llike that as well.
Well as i am searching now, I see Duratrax better. Sunday there is a race and I will have a talk with the other guys. I will search for APS also.
The new APS Dyno Charge is a great value. The motor test functions are awesome. The charging is similar to other mid-high end chargers. You'll need a good power supply. I paid $155 from All Speed. www.allspeedhobbies.com
Registered User
the ICE or the PULSAR are the best choices.
Check out Cell Master from Muchmore Racing...... it is a true linear charger and the CTX function is awesome...... I dont know what retail price is in the US but in canada it sells for $240 Cnd..... Same charger that Rheinard, Surikarn and Hara uses so you know its good stuff...... it is not widely available yet in North america ( it should be soon), contact Debbie at Raincity Raceway in Seattle, they are one of the distributors........ and APS is good as well......
Muchmore Racing Link
I think that all the chargers that we are talking about should do aprox. tha same job.
One may have sth more one sth less.
Still searching...
Also i tried to find CTX but it is too expensive to get it grom Japan ( I live in Greece).
Still searching...
My $0.02
Stephen <><
Tre's if you read this are you going to make a plate for the APS Dyno-Charge????HINT HINT
