Kyosho FW-05R - many upgrades and a ton of spare parts
Hi,
I am selling my Kyosho FW-05R nitro TC kit. I didn't even run a full tank of gas through it this summer due to no time to race. My prospects of being able to race it any time soon are not looking much better so for sale it goes.
All you need to add are electronics and an engine.
With Car:
FW-05R
98% of screws replaced with hex-head screws
gas tank
drilled brake disk
upgraded brake pads
graphite upper deck
39T steel ring gears
Kawahara front-end coversion kit
Alloy clamping hexes (front and rear)
Universal drive-shafts (front)
Antenna tube
Kyosho tuned exhaust pipe and header
Kawahara carbon steering plate (adjustable ackerman)
3Racing front carbon lower arm pin mount
Gear Diffs front and rear
(3Racing One-way with 39T steel ring gear)
Kyosho centax clutch
1 set lowered aluminum motor mounts
1 set kit engine mounts
3racig lightweight 1st spur gear housing
Parma 200mm Alfa body
Set of new foam tires
New, Not-In Package:
front shock tower/upper arm mount
rear shock tower/upper camber link mount
set of front upper/lower arms
set of rear arms
front shock tower
rear shock tower
differntial case
2 full sets, kit 40T ring gears
New, In Package:
5x Kyosho front steering knuckles
4x Kyosho carbon composite front suspension arms
4x Kyosho carbon composite rear suspension arms
1x Kyosho carbon front shock stay/tower
2x Kyosho diff gear set
1x Kyosho bevel shaft set
2x Kyosho differential joint
1x Kyosho pair universal swing shaft (for front one-way)
1x Kyosho pair swing shaft (rear)
1x Kyosho rear bulkhead set
2x Kyosho differential case
3x Kyosho 27T 2nd gear pinion
1x Kyosho 28T 2nd gear pinion
2x Kyosho 23T 1st gear pinion
1x Kyosho 51T 1st spur gear
1x Kyosho 45T 2nd spur gear
2x Kyosho 46T 2nd spur gear
1x 3Racing one-way hub and outdrive joint kit
1x 3Racing aluminum hardened center shaft
1x Kfactory pair one-way joint cup
1x Kfactory 22T clutch gear
Other miscellaneous parts
Instruction manual
clutch pinions
kit spur gears
Pics:
http://richardchang.com/hobby/fw05_chassis_top.jpg
http://richardchang.com/hobby/fw05_chassis_bottom.jpg
http://richardchang.com/hobby/fw05_parts.jpg
http://richardchang.com/hobby/fw05_spares_a.jpg
http://richardchang.com/hobby/fw05_spares_b.jpg
$510 shipped obo.
Email me at [email protected].
-Rich
With Car:
FW-05R
gas tank
drilled brake disk
upgraded brake pads
graphite upper deck
Antenna tube
set of rear arms
front shock tower
rear shock tower
differntial case
New, In Package:
Instruction manual
clutch pinions
kit spur gears
Pics:
$510 shipped obo.
-Rich
Any interest?
Still available. Make an offer.
