2 1/2 Yokomo GT4s
2 1/2 Yokomo GT4s
Everything in the picturers will be included except for the engine an pipe on the one car. I will include the Sirio engine with the centax and the Yokomo pipe and header. Also included is another engine, a Picco rear exhaust, both engines are in good shape. There’s also another chassis plate, and I will include a floating rear body mount. I could list everything included, but just look at the pictures to know what you will get.
There’s almost enough to build a third car here, you will not have to buy another part if you get this package.
No electronics included.
Im looking for $800, make offers.
One car has an aluminum midlle layshaft mount, an aluminum midlle layshaft, and lightwaight 2 speed shaft. It also has Penguin graphite shocktower braces, Penguin graphite rear bulkhead brace and an aluminum rear shock tower. It also comes with a front and rear sway bar and a aluminum upper deck. And lets not forget the 4mm custom chassis.
The other car has a lightwaight midlle layshaft, an aluminum rear bulkhead brace and factory 3.2mm chassis.
