Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 01-13-2012, 01:18 PM   #1
Default ESC - Drag Brake?
Hi
Could someone explain what the drag brake setting is, what it does and what effect it has on the car (1/10 touring car)?
kosmickid is offline   Reply With Quote
Old 01-13-2012, 01:43 PM   #2
nhmade's Avatar
Trader Rating: 54 (100%+)
To put it simple...From novaks site...
Drag Brake turns the dead band area between throttle and brakes into a preset amount of brakes, which eliminates the time, or dead space, to travel from brakes to throttle.
styrene servic for hire.hehe
nhmade is offline   Reply With Quote
Old 01-13-2012, 01:59 PM   #3
ChooChoo1800's Avatar
What ^ he said.
When you let off of the throttle and the trigger is at rest, a preset ammount of brake is immediately applied.
ChooChoo1800 is offline   Reply With Quote
Old 01-13-2012, 04:07 PM   #4
hotrod87's Avatar
Trader Rating: 180 (100%+)
Drag brakes also make a brushless motor feel more like a brushed motor .When you let off the throttle it has drag on it.
RULE #1 HE WHO HAS THE LOWEST FEEDBACK SHIPS FIRST
RULE #2 ALWAYS FOLLOW RULE 1
hotrod87 is offline   Reply With Quote
Old 01-13-2012, 04:37 PM   #5
Thanks all. I read somewhere that drag brake should be reduced for low grip/ slippery surfaces?
Old 01-14-2012, 02:27 PM   #6
blis's Avatar
Indeed, as you want to free roll the slippery areas and not have brake applying when you dont want it. Unless you want to ride the throttle (not enter dead band) which is hard to do Drag brakes can also work variably, so the faster you are going the more braking you get when in the dead band.
I personally turn the drag right down until the car behaves well in the dead band relative to the track conditions. Just enough to behave like a engine/compression brake in a 1:1 car.
RC Cars: E4/G4/V10/TCX /LAB-C02
Club: England Park Raceway - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 01-14-2014, 06:49 AM   #7
that's what I prefer too. just enough to where I get light lift-off oversteer. ensures that I don't plow
EDIT: GRAVE DIGGING. sorry. didn't realize the thread was ancient
Racer: SCT410, RX8v2, Pro4HD 4300, SB-2271SG
Bashers: Slash 4x4 VXL, Losi 1/24 Brushless Rally
5errated is offline   Reply With Quote
Old 01-14-2014, 11:41 AM   #8
ThePanda's Avatar
Trader Rating: 37 (100%+)
we have all done it before
"Ohana means family. Family means nobody gets left behind — or forgotten."
—Lilo Pelekai
Now I also have a XV-01 Pro!
ThePanda is offline   Reply With Quote
Old 01-14-2014, 12:36 PM   #9
Good to know...
FinishLineSport is offline   Reply With Quote
Old 01-14-2014, 12:39 PM   #10
EricW's Avatar
Personally I've moved away from using any drag brake at all, it's forced me to learn better throttle/brake control. Plus I have my brakes set so low that it only slows me down just enough to get the weight to transfer to the front wheels. Also, I've been told drag brake will increase heat in the motor as its like always have your brakes on.
My stuff: Team Associated 2WD FT SC10/B5 * Airtronics * Tekin * SMC * Schuur Speed * Reedy * Spec-R S1 * HobbyWing * Xray Xb4'14*
**** "Luxury" ****
EricW is offline   Reply With Quote
Sponsored Links
Drag brake purpose? So*Cal AFDude Electric Off-Road 20 02-08-2011 03:09 PM
How important is a drag brake? TNBiscuit83 Crawler Room 8 10-29-2010 05:33 PM
Drag Brake on Novak GTB, LRP TC Spec rcjunkie3000 Rookie Zone 8 07-16-2008 07:28 AM
Brushless Modified Cogging/Drag Brake Effect per different brands... StickyFingaz Electric On-Road 8 04-10-2008 06:07 PM
Search Engine Optimization by vBSEO 3.5.0
