How do you fix a bent pipe?
I just bought a pipe and i got hit in the side during the race, and i was wondering if there was any trick on getting the dent out? thanks for you help
You can take the pipe and cover the stinger and the fitting on top of the pipe
and take the header of. Next fill the pipe with water and put it in the freezer( just like you ar going to make ice cubes) After 15-20minutes keep an eye on the pipe and you will see that the dent will start to come out. Make sure you keep on checking it because if you leave it in the freezer for to much time then you will have a balloon of metal instead of a pipe!!
hope this helps
hope this helps
bump
I also herd about Heating the pipe up with a torch and then using a high powered airgun... Apperciate the help..
hope this helps
hope this helps
overnight freezing works well, but depends on what brand of pipes u guys running,, its not working for my JP pipe and OS speed pipe. but for rtr pipe is should be easy.
Freeze method
I just fixed a pipe of mine. I had a dent on top. Plus the stinger was pushed inn pretty good. I had to plug all the holes. Plus wire tied the plugs so the ice wouldn't push the plugs out. It worked perfect. It was a Werks pipe.
It's like new. It took about a 1 hour or so. Good luck
The freeze method is the best....
