Losi XXX-S
#8566
Originally posted by J.Filipow
I have a great chart for ratios, in 64 pitch for both 41T and 42T pulleys, and rollouts, with both standard and metric tire measurements. Email me if you would like a copy as a JPEG file.
#8567
#8569
older screw, i know it has threads on it, the nut has threads on it, but does the little plastic housing the nut goes in, with those two little tabs on each side. Do you need to run with that, i have my diff together, but that is still on the table. I read the instructions i printed off. I put 6 concave washers in, then the nut/nut housing on. i threaded the screw threw the nut, but then it would stop, and the housing kept fallin out. So i took the housing off, and everything worked fine. Now i can see the nut, screw, from one side(other being the flat head end).
#8570
You HAVE to use the tnut! It and the nut usually come as one piece now. Without it, the the nut will spin and come loose.
There is your problem.
Later EddieO
Later EddieO
#8571
thank you! I was at the lhs today, and bought a bag of diff parts, and i just need the spacers, but there was another nut in there, but with like a solid silver thing in the middle, where the nut would be, and the silver thing has theads in it, is that the one piece thing. It looks like a big spacer in the middle of the nut.
#8573
The losi site has exploded views of the diff assembly. Typically the tnut and nut come already together, but occasionally the nut is out. HG made a solid piece of threaded aluminum to replace the nut/tnut combo. I used one on my XXX, but it is a bit heavier than the stock combo.....and additional rotating mass SUCKS in onroad.
Later EddieO
Later EddieO
#8574
Trader Rating: 32 (100%+)
#8575
great, my tag says "diff screw, hardware, and seal set" great. I finally have my diff installed, everything works great, i appreciate all the help you guys gave me. Part number 3078, just for further infomation. Now back to rebuilding this beast, lol.
#8576
I almost bought that same wrong Losi dif parts bag last weekend. Yep, A-3078 is the winner.
Now, go get em...Happy racin'
#8577
yea, when i was at the store, i sat there wondering, which one should i buy?(the two guys working there, well, i knew about twice as much as they did, lol). I was like, buy this, or that, or both. I picked the right one. Now i just have to figure out how to get some AE hexs, that i forgot.
Sat: work 11:00-5:00, store: 11:00-5:00
Sunday: Same thing, but store closes at 4
Monday: School(home at 3:30, homework, eat dinner, pack up), leave at 5 for race.
#8578
#8579
no worry. my dad said he'll pick the stuff up today for me. Hey, i need a quick response on this, whats the difference between the losi red(with o-ring) hexs, and the AE hexs that everybody uses.
#8580
Location: A step closer to where I need to be a step further from where I was
AE hexes are wider
