motor rewinding help
Is it really worth that? Wouldn't it be cheaper and easier to buy a new armature?
Rewinding armatures is easy.
The problem is getting the correct wires and solder or weld the ends of the wires in place, the motor can get hot enough in normal use to melt normal solder.
When you wind you have to wind in the right direction around each pole and connect the wire to the right connection.
Then you have to dip the armature in epoxy paint to sort of glue the armature wires into place. This prevents the motor from throwing a wind.
And finally you have to balance the armature. If you wound the armature carefully the balance should be very good and only minirature adjustments needed.
Have fun experimenting.
