Has anyone tried to rewind brushless motor?
The most interesting thing about brushless is IMHO the fact that you can wind your own :-).
No balancing issues to worry about.
Do you want 1.5 turn? DIY.
Has anyone tried this?
are you kidding...
True, you don't need to worry about rotational balance but more importantly you have to worry about phase balance. If one phase generates more of a magnetic field than the others, the motor will not run smoothly. Unless you want to risk blowing your ESC don't even try.
You will never learn unless you try it.
Give it a shot!
Bxpitbull. Why flaming mad ? True, the winds are in the can. But, that's why it's so easy.
I want to try it to see what happens. Same reason why I was one of the first to put backlight in Duratrax Ice, now everyone and their grandmother is doing that.
BlueBird-sr. Phase balance? What exactly is that. I'm electrician, I've wound dozens of full size motors, some weighing couple of hundred kilos but I don't recognize that expression. Then again English is not my native language. If you wind the motor in the same way it was wound (except for number of turns and thickness of wire) using 1 or 2 less winds than original, and connect it in the same way it was connected. How can it be out of phase? If you're worried about destroying expensive ESC let me inform you that LRP has very good budget brushless ESC.
Flaming may have been harsh, but, like anything else, why would you want to?
as Kyle478 said above, you'll never know unless you try it.
Take it apart and play with it..the motor i mean.
A better reason to ask why though, is when you look at the "for sale" threads. Seems like every week there's someone getting rid of a 3.5/4.5 motor because it's too fast. Considering the cost is less than $90 for a stock or fastest motor out there , I'm not sure I see the benefit. Unless you just want to play.
Airplane guys have been hand building brushless motors. They sell CD-rom drive motors kits where you recieve all the supplies, all you have to do is wind the wire up.
Example:
http://www.gobrushless.com/store/cgi...brushless+kits
Example:
One reason why someone would want to wind brushless motor is if the motor has broken. It could be short circuit in the windings or broken wire from vibration.
Don't forget that these motors have to be wound in the first place. It's not done by magic and they don't pop into existence out of nothing. These small motors it's most likely built by hand.
My, my, you did. I didn't read it that way. Loops of wire, or winds, are not called phases. I assumed that most people have some intelligence and I didn't think anyone would be stupid enough to do what would be equivalent of winding brushed motor with one pole 10 turn, the next 12 turn and the third 11 turn. (As an interesting side issue, Honda did experiment and race (and win races) with motorcycle-motors in GP500 racing that worked on what they called "big bang theory" were both cylinders "banged" at nearly the same time, giving very pulsing power output. This was supposed to give the bikes more rear grip since the rear tire was just rolling for large part of its turning circle). I know every wind has to be same number of turns (unless you have multispeed motor, with two or more sets of wires, which I'm not going to go into here) so I apologize for assuming that everyone knows that.
Drew.
