Novak GTB/SS10.5 Pro Brushless System
I thought i'd start a separate thread for the 10.5 brushless system. This is Novak's brushless motor thats performs similar to a 19T motor.
# GTB/SS10.5 Pro Brushless System—this system is ideal for use in “SS4300 class” races with performance similar to 19-turn brush motor. (#3010)
More info here:
http://www.teamnovak.com/products/br...ems/index.html
Post away!
More info here:
Post away!
ihave just got a 10.5 system what roll out should i use . i use 32.92 mm at press with a 19t atlas ea motor. rubber tyres on carpet please some one give me a starting point.
The Evicerator
With rubber tires I usually recommend starting out with a 5.5:1 Final Drive in touring car.
With a 64 mm rubber tire that rollout would equal 36.5 mm.
Hope this helps!
Hope this helps!
Hope this helps!
Hope this helps!
Just got Mine..
Harsh said he is running at 5.1
Hope this helps!
Hope this helps!
thanks
Hope this helps!
Hope this helps!
so i need to gear up from 74/29 to 74/32 is this correct as on the instructions it says gear down
The Evicerator
Big B: I believe that the gtb/SS pro combos should be shipping already...? I might be wrong though... the motors by themselves have been available for quite a while now.
As far as 1/12 gearing goes... I want to say that the last time I ran the 10.5 pro spec motor I ran a 98/35 with 45 mm tires?
I don't have everything in front of me and I will have to double check on all of that later to be sure.
Aid: It depends on what the internal drive ratio of your car is... I don't know what car you are driving
i drive a cyclone
thanks for the quick responce
The Evicerator
Yeah a 32 or a 33 tooth pinion will be a good place to start out.
gear ratio in a losi
can someone please tell me how should I gear a losi jrxs with 128 spur with the SS 10.5 pro with sintered rotor?
My motor is arriving late this week and I would like to start testing with something aproximate.
Thanks.
Thanks.
The Evicerator
Start out with a 42 or 43 tooth spur gear!
I generally recommend starting out around a 5.5 and those pinion gears will get you just on either side of it.
Steve
what drag brake do i need to start with so it feels the same as my brushed motor did with gtx and no drag brake stick in neutral possition
Aid
Aid
