Team Losi JRXS Type-R
#6361
make that a double.
#6362
Hey guys, here's a setup for those that don't run traction compound for rubber on carpet (ozite). Car drives quite well, and has heaps of on-power steering and a slight push off power. Haven't tried it with any traction compound, so feel free to try and let me know. My local Aussie track does not allow use of compound...
Have fun boys!!
Have fun boys!!
#6363
#6364
Anyone try Orion 3600 25C pack in their Type R, yet? I just bought one and its rear rubs on the middle shaft pulleys, since its 47mm wide
I'd really hate dremmeling the pack to get it to fit...but maybe its the only way. Unless there's a way to shim out the pulleys 1mm on eah side to make it wider so the 47mm 3600 Orion pack can fit and not rub on the pulleys...
Suggestions? Anyone get one and have the same pblm?
#6365
#6366
what spur gear are people running with the orion/peak 10.5 motors... can't get the gearing right with the 128, the motor hits the suspension block and can't put on the right size pinion... is there any other make of spur that can be used in the car?
#6368
They make other size stock spurs for it and you can also do a PRS spur gear adapter to use those spurs as well.
#6372
YOHANAN, YOHANAN, YOH...ANAN, YOHANAN?
Your problem is my things till You solve it, go to figure out! that why you and I are unfinish our business!
==> Thread: Sale/Trade: Losi JRX-S Type R for sale
#6375
i agree.....please remove the post.....it belongs elswhere.....
