Kyosho Lazer SB Dirt Cross
Looks like the ZX5 is re-released. This might make a solid 4wd buggy for club racing on a budget.
FUKUYAMA RC Center
* Threaded oil shocks
* Retro styled wheels
* Adjustable tie-rods and upper rods
* Cab rearward body
* Rear gear diff, optional ball diffs
* Polycarbonate gear cover
* Updated slipper clutch
* Ball bearing equipped
* All hex hardware
* Battery tray updated
* Wheelbase – 268.5mm
* Width – 245mm
FUKUYAMA RC Center
* Cab rearward body
* All hex hardware
* Width – 245mm
I thinks it's odd how they described the rear gear diff...
What's in the front gearbox then????
Looks a little "plasticky". I wonder if it will hold up to 13.5 racing heat after heat......
But any new option is welcome.......
Looks to be based on the ZX5-SP rather than the original.
I raced ZX5-SP and ZX5-FS for several years on astro and carpet with up to a 5.5 mod motor without any real issues of breakages. The ball diffs of the original car was the weak point so this should be stronger still with gear diffs.
I wonder how the price will compare to something like the LC Racing PTG-1 which is only $250 and has things like aluminum big bore shocks.
Slipper assembly
Universal driveshafts
Metal Hexes / Axles
Hard ball cups
Aluminum lock nuts
YMMV - but I'm buying one of these.
cab rearward body has to be listed as a thing?
Zx5 4 evah
I have a zx5 fs2... and yay for me! Spare parts 4 evah!
Truth to tell, the zx5 was a super nice car to drive. The original had some durability issues:
* c-hub and front hub was super weak
* shock tower mount was super weak
* chassis had holes for the motor, nicad/nimh batteries and spur gear > leading to a lot of stripped spurs
* original had a funky ball diff/front one way/front spool that wasn't ao durable
*super flexi wing mount
Everything was improved in later zx5 models...
It looks like kyosho has dealt with all the major durability issues in this car.
Yep - also, I think the market for "nostalgia-ish" racing is far bigger in Japan than it is in other parts of the world. If you watch Kai City RC's Youtube channel, you'll see that they have fairly large events for vintage, repro, and "modern vintage-style" racing over there. So, the cab-rearward body is a key requirement.
