Kyosho Lazer ZX7 Thread
#167
Both offset change and 5mm hole are correspondence with ifmra rule.
#168
I do hope Kyosho jumps back in the 4wd 1:10 buggy arena again sometime soon. They have always impressed me over the last three decades with design and quality. I still run my ZX7 competitively on carpet along side, and often in front of the latest and "greatest chassis currently on the market. I have a Yokomo YZ4SF2, Schumacher, and Associated that are collecting dust on the shelf as the Kyosho is just better... at least for my driving style. Come on KYOSHO, get hungry for the world championship again.
#169
I am also holding out for Kyosho to jump back into 1/10 racing.
#170
13.5 Carpet Set-up Sheet Recommendations & Tips for Racing Zx7
Curious if anyone following this thread can point me to a good set-up sheet to run the Zx7 13.5 spec on indoor black carpet track 90’ x 40’ with more technical / tight layouts.
The majority of what I have seen on petitrc as far as carpet for this buggy is for mod/lower turn motors. Just built the kit and took it out for its first time last night (sat NIB on shelf for way too long).
Any additional tips for club racing this chasis?
#171
There are some carpet set ups in the 'files section' of the Kyosho Off Road Army facebook group, some good ones from Duncan Nattress (UK Racer)
#172
First time run a brand new Kyosho Lazer ZX7 for the 3rd round of the Spanish National Series! This car just surprised everyone in the field as it was probably the fastest cornering, braking and accelerating car in there
I was able to get an 8th after having many issues with the 4200mah lipos not lasting a 7min main. The car just stopped in the last lap of the first main because of the lipo cut-off.
I removed it for the second main but the car completely lost power in the last 2 corners, forcing me to give up 2 positions and leaving me in the 6th place.
Fortunately, a friend of mine was able to find a 6300mah lipo for the last main final. Ended up 5th for an overall 8th place in the A-main.
Really happy with the car with just a couple changes from box stock.
#174
#176
anyone have a zx-7 4wd dirt buggy for sale ??
#177
Is diff height adjustment a big deal? If so, maybe design it with diff height inserts also. The stock zx5/6/7 gearbox design would make an excellent platform for inserts, with some dimensional massaging.
#178
It's a big deal if you need that little extra umph to get you on the podium. It only helps if the driver can get a around a track without crashing. It offers a tad more speed due to having the level drive shafts. Currently, to raise the diff, on the ZX, you will have to raise the entire gear box. However, this can raise the center of gravity. But then some will argue that the weight difference is not enough to worry about, and it will also raise the shocks so your suspension travel doesn't change.
#180
Has to be said, the few that were at the worlds went surprisingly well, the parts question might be a problem though, here in the UK i would say support is very scarce at best.
